So thinking to put a rb26 on a rb20de. I think the bore and centres are the same, but i don't think bolt sizes are and the valves won't like the smaller bore.
At the end of the day, do you think its worth it? and why?
Thanks.
https://www.sau.com.au/forums/topic/398473-rb20de-w-rb26-head/
Well, it can be modded to fit, the topic isn't to be told what i shouldn't do. I plan on keeping my NA off my P's and keep it as a daily driver untill i get sick of it, and the idea of 140-150KW RB NA sounds good to me.
Just want to be different.
... and the idea of 140-150KW RB NA sounds good to me.
How do you intend to get this sort of power?
The RB20 is a much smaller bore than the RB26. So the combustion chamber of a RB26 is considerably larger than the RB20's. The piston at TDC will be like a dick-in-a-bucket fit into the chamber. The thing will have such low compression that you might be lucky to even start the engine.
And the RB25 bore is the same as the 26.
a 140-150kw would make an ordinary daily driver. a stock or mildly modded turbo skyline would be a better daily driver.
You do realise it is a modified motor, and therefore illegal - be it N/A or turbo makes no difference.
mohsen don't encourge him... this is why i hang out here to prevent stuff like this from happening. read up on gregs thread with the rb30 bitten end with a 26 head. thats the ultimate rb skyline natro you can make.... and as a daily i duno if you'd really enjoy driving round in a camed up natro just for the daily grind.
if you wana do.it do it, but its a lot of $'s for the sake of being different.
