  • 1 month later...
DJC: Please read the rules or this thread will be closed. Post ALL relevant vehicle and sale information in this thread. A link to the information is not sufficient.
Thank you
My apologies,
Toyota Soarer GT-Limited
1991
139,000Km
Registered to March 2005
4.0 V8 quad cam
Jade Green
Standard except for 17' wheels
Lowering control
Factory TV
Leather in near perfect condition
4 Wheel Disc Brakes
Abs
Air Conditioning
Alarm/Immobiliser
17 inch Alloy Wheels
Auto Climate Control
Cd Player - 12 stack changer
Factory 7 split speaker system including 10' sub
Cruise Control
Drivers Airbag
Electric Mirrors - with defogging
Fuel Injection
Independent Rear Suspension
Leather Trim
Power Steering
Power Windows
Remote Boot/Hatch Release
Remote Central Locking
Electronic Automatic Tilt Steering Wheel
Tinted Windows
Trip Computer
$15,500
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
