  • 1 month later...
DJC: Please read the rules or this thread will be closed. Post ALL relevant vehicle and sale information in this thread. A link to the information is not sufficient.
Thank you
My apologies,
Toyota Soarer GT-Limited
1991
139,000Km
Registered to March 2005
4.0 V8 quad cam
Jade Green
Standard except for 17' wheels
Lowering control
Factory TV
Leather in near perfect condition
4 Wheel Disc Brakes
Abs
Air Conditioning
Alarm/Immobiliser
17 inch Alloy Wheels
Auto Climate Control
Cd Player - 12 stack changer
Factory 7 split speaker system including 10' sub
Cruise Control
Drivers Airbag
Electric Mirrors - with defogging
Fuel Injection
Independent Rear Suspension
Leather Trim
Power Steering
Power Windows
Remote Boot/Hatch Release
Remote Central Locking
Electronic Automatic Tilt Steering Wheel
Tinted Windows
Trip Computer
$15,500
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
