Apexi Power FC Boost Control Kit off my nissan S14a.
PFCBOOSTKIT-415A013
Has been used for about 1 year now, selling the car so no need for this.
The Apexi Boost Control Kit is an optional kit designed to control boost through the Apexi Power FC. Simple connection to the Apexi Power FC allows the user to access a full self-learning boost controller. The Apexi Power FC allows up to 4 different boost presets for any stage of driving. The high grade solenoid valve is the same one used in our Apexi Super AVC-R boost controller. As with the Apexi AVC-R, the Boost control kit allows increased boost response and boost stability at high RPM's
Also suits:
Nissan Silvia - PS13 (Red Top)
Nissan Silvia - S14 S2
Nissan Silvia - S15
Nissan 180SX - RPS13 S2 (Black Head)
Nissan 180SX - RPS13 S1 (Red Head)
Nissan 180SX - RPS13 S3 (Black Head)
Nissan Skyline - R34 GTT - ER34
Mitsubishi EVO CP9A
Mitsubishi EVO CT9A
Subaru Impreza - GC8/GF8 Ver3-4
Subaru Impreza - GC8/GF8 Ver5-6
Comes with original box, Apexi boost solenoid, cable to Apexi Power FC and 1 meter of vacuum hose (not pictured)
Condition: Used
Age/Mileage: 15,000kms
Price: $ 300 (RRP at justjap is $730)
Edited by philmak
Do u no if this would suit a r34 gtr ??
Nope you need
BCK 415-A001
http://justjap.com/store/product.php?productid=18036
These are more common to find second hand.
  • 1 month later...
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
    • Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
