Hey guys,
Quick question as no clutch shop will give me a straight answer...
Im after a new clutch for my R34 GT-T, Currently modded with FMIC, BOV, Pod filter, full 3' exhaust, and my Shiney new eboost street :D.
Im looking to get it tuned as soon as i have the clutch installed with a nistune, First Question is Which clutch do i buy?? all shops ive been to say what is the torque of your car, Problem being, i dont know untill i get a tune, and i cant get a tune till i have a clutch!
2nd question, Before the tune, Are there any other supporting mods i should look into as to make the tune more economical/beneficial? ive heard Z32, Fuel pump, Coil packs. But not sure what can be overlooked and installed later, or what needs to be installed for the tune.
Any advice or opinions greatly appreciated, Cheers guys!
Edited by EuphXP
https://www.sau.com.au/forums/topic/398503-which-clutch-s/
I am running an Exedy cushioned button clutch, happy with the way it drives and feels....price was a bit of a kick in the teeth though.....
Cant remember what they are rated too, i think it was a tad over 300kw so it should be more than enough for your needs...
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6328715
In regards to which clutch you should buy it is basically a question of do you have any future plans for more power or what is your future power goal and get a clutch to suit that. But with the setup listed something like a heavy duty exedy clutch for a few 100 will be more than enough. For the other mods youve listed coilpacks only need to be done if your ones are stuffed and z32 wouldnt really be needed until you probably do your turbo and start pushing more power where your stock afm is at its limits but the fuel pump would be worth replacing if you want to do it for piece of mind but again for that setup you listed not essential.
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6328719
Wasnt looking to spend an arm and a leg, and as for future mods, im only aiming for ~250awkw for the time being,
Ive got 2k set aside for my clutch installed, and have been quoted for the nistune installed and tuned for $1100.
Was just going to use my local mechanic for the clutch install, just need to know which clutch to throw in it...
Ive had a look at the exedy clutch kits, as with the NPC Kits and was quoted for a heavy duty organic clutch kit. $753.50. My mechanic said he would rather work with exedy as he has contacts.
If i was to go exedy, which clutch kit do i go? Heavy duty? Button? Ceramic?
And as for the flywheel, ive heard with ceramic clutches its best to get a new flywheel to improve the life of the clutch, ive also heard that theres no need to do flywheel >.<
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6328787
you should never put a lightweight flywheel in a street car... totally goes against anything streetable
it's come with the clutch. this one-> http://www.nismo.co.jp/en/products/competition/clutch/sckit.html
so npc organic clutch will be better than this one for street use?
Cheers!
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6329664
Npc also do a 10" organic clutch which is rated to 280 rwkw. Jap__star on here has one and pushing 300 rwkw. Very driveable and would be perfect for a street car.
We regularly put these in cars making 300rwkw without issues. They can hold a lot more torque than we give them credit for and being a pull type clutch, they will hold more torque than their push type counterpart.
would the carbotic 10" handle 325rwkw...?
We've tested them to 600rwhp, drag racing 9k GTR launches, track work for years. They will eventually wear out if abused or not driven correctly. It's usually the latter that gets most people on their first button clutch
which one is better for street use?
nismo clutch kit(the basic one with lightweight fly wheel that one) or npc organic clutch?
I would highly recommend the NPC Organic 10". Have fitted them to many cars. Get nothing but rave reviews from each person every time. Be careful over 400hp though, we don't often push them harder than that so how far they will go is still relatively unknown
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6329751
I have had both a Organic NPC and a Bigmouth track NPC button.
The organic is better for every day use, I was pushing 450hp when my GTR was my daily and not an issue what so ever until of course wear took place. I was doing 6500-7000rpm launches getting my 1/4mile time down to a 12.385 at 111mph when I decided the clutch had enough it was slipping at the top end of my gears mainly second and 3rd.
I asked MANY MANY suggestions on which way to go after killing the organic. Dan(ERD), Noel(Fineline), Strik3r, Hyped6 and Strudel.
A majority suggested the Bigmouth track, and I am glad I listened to them. The clutch is a little adsertive and obviously doesn't like being ridden like a button clutch shouldn't be, but in traffic somewhat difficult to avoid. but 1 of the best things I had in my GTR. Not as piggy as some of the button clutches I have driven and VERY liveable.
My clutch is still holding out and I don't expect having to upgrade for a long long time, so It's my recomendation.
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6330070
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
