Hey guys,
Quick question as no clutch shop will give me a straight answer...
Im after a new clutch for my R34 GT-T, Currently modded with FMIC, BOV, Pod filter, full 3' exhaust, and my Shiney new eboost street :D.
Im looking to get it tuned as soon as i have the clutch installed with a nistune, First Question is Which clutch do i buy?? all shops ive been to say what is the torque of your car, Problem being, i dont know untill i get a tune, and i cant get a tune till i have a clutch!
2nd question, Before the tune, Are there any other supporting mods i should look into as to make the tune more economical/beneficial? ive heard Z32, Fuel pump, Coil packs. But not sure what can be overlooked and installed later, or what needs to be installed for the tune.
Any advice or opinions greatly appreciated, Cheers guys!
Edited by EuphXP
https://www.sau.com.au/forums/topic/398503-which-clutch-s/
I am running an Exedy cushioned button clutch, happy with the way it drives and feels....price was a bit of a kick in the teeth though.....
Cant remember what they are rated too, i think it was a tad over 300kw so it should be more than enough for your needs...
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6328715
In regards to which clutch you should buy it is basically a question of do you have any future plans for more power or what is your future power goal and get a clutch to suit that. But with the setup listed something like a heavy duty exedy clutch for a few 100 will be more than enough. For the other mods youve listed coilpacks only need to be done if your ones are stuffed and z32 wouldnt really be needed until you probably do your turbo and start pushing more power where your stock afm is at its limits but the fuel pump would be worth replacing if you want to do it for piece of mind but again for that setup you listed not essential.
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6328719
Wasnt looking to spend an arm and a leg, and as for future mods, im only aiming for ~250awkw for the time being,
Ive got 2k set aside for my clutch installed, and have been quoted for the nistune installed and tuned for $1100.
Was just going to use my local mechanic for the clutch install, just need to know which clutch to throw in it...
Ive had a look at the exedy clutch kits, as with the NPC Kits and was quoted for a heavy duty organic clutch kit. $753.50. My mechanic said he would rather work with exedy as he has contacts.
If i was to go exedy, which clutch kit do i go? Heavy duty? Button? Ceramic?
And as for the flywheel, ive heard with ceramic clutches its best to get a new flywheel to improve the life of the clutch, ive also heard that theres no need to do flywheel >.<
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6328787
you should never put a lightweight flywheel in a street car... totally goes against anything streetable
it's come with the clutch. this one-> http://www.nismo.co.jp/en/products/competition/clutch/sckit.html
so npc organic clutch will be better than this one for street use?
Cheers!
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6329664
Npc also do a 10" organic clutch which is rated to 280 rwkw. Jap__star on here has one and pushing 300 rwkw. Very driveable and would be perfect for a street car.
We regularly put these in cars making 300rwkw without issues. They can hold a lot more torque than we give them credit for and being a pull type clutch, they will hold more torque than their push type counterpart.
would the carbotic 10" handle 325rwkw...?
We've tested them to 600rwhp, drag racing 9k GTR launches, track work for years. They will eventually wear out if abused or not driven correctly. It's usually the latter that gets most people on their first button clutch
which one is better for street use?
nismo clutch kit(the basic one with lightweight fly wheel that one) or npc organic clutch?
I would highly recommend the NPC Organic 10". Have fitted them to many cars. Get nothing but rave reviews from each person every time. Be careful over 400hp though, we don't often push them harder than that so how far they will go is still relatively unknown
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6329751
I have had both a Organic NPC and a Bigmouth track NPC button.
The organic is better for every day use, I was pushing 450hp when my GTR was my daily and not an issue what so ever until of course wear took place. I was doing 6500-7000rpm launches getting my 1/4mile time down to a 12.385 at 111mph when I decided the clutch had enough it was slipping at the top end of my gears mainly second and 3rd.
I asked MANY MANY suggestions on which way to go after killing the organic. Dan(ERD), Noel(Fineline), Strik3r, Hyped6 and Strudel.
A majority suggested the Bigmouth track, and I am glad I listened to them. The clutch is a little adsertive and obviously doesn't like being ridden like a button clutch shouldn't be, but in traffic somewhat difficult to avoid. but 1 of the best things I had in my GTR. Not as piggy as some of the button clutches I have driven and VERY liveable.
My clutch is still holding out and I don't expect having to upgrade for a long long time, so It's my recomendation.
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6330070
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
