I just got a clutch from KB clutches in Sydney.
He was a really nice bloke that asked everything to do with the car and the power/rpm/use
Managed to pick something up for $410 including postage to ACT
Only time will tell if it holds up or not.
But I currently am pushing around 240-250rwkw
I know this is an old thread but i did a quick search and didnt find what i was looking for, what is the Exedy cushioned Button 34GTT clutch rated too power wise? I think it was 330rwkw from memory, but if somebody has a better indication please let me know as i will probably let the guys know before they tune it ;)
I'm hoping my cushioned button holds up, should do for a while as it hasnt done a huge amount of work..... Just not sure of what its rated too?
Next clutch for mine will be the JB i think as i was told they are good to drive :D
Softer than stock pedal, no shudder, holds massive power.
Hmmmm mine definately shudders which is sent down my drive train to my diff. Subsequently, the backlash in the diff is sloppy as and all I hear is loud thuds if you sit on the clutch longer than a second. Clutch has done about 3-4000km's since new. Flywheel was machined by JB aswell. I thought it might be just a wearing in issue, but it would seem its not!
Also, how does yours take up/grip? I've found mine goes from OFF to ON in a VERY small range of movement...
Edited by R32Abuser
That can't be right surely?
It's a single plate clutch. Can get the same thing from NPC with brand new parts instead of the JB second hand ones. NPC are only about $750-$800
Ive seen people quote like $1300 odd on here.
If it was 2k then I would not even consider him and just go straight for a nismo coppermix! or if you dont have the coin then get a NPC clutch.
The shuddering might be caused by the cracks in the second hand pressure plate
got mine for about $1000
4100 lbs of clamping force. Plenty of clamp for my application - if anything its WAYYYYY overkill considering its a street car.
Elite/Daniel, surely JB would have seen this? This has happened from day one, and he said that it would initially shudder but would come good after 1000km's.
They go for about $1200 depends on what you get. The shudder could be from contamination, oil and crap getting on the flywheel makes it glaze, hence shudder.
Yeh my clutch has a small friction point, 100kms of driving and you get used to it.
Just for reference, the pricing on the GTT was quite a lot more than a GTST as they are the pull time clutch etc..... My Exedy was around $1300 at trade price at the time i got it (They have probably come down a lot now) but the 34 clutches were quite expensive..... Just like EVERYTHING else on the damn things that is slightly different to the other models :glare:
If your poor ten obviously your going to go for the cheapest option
Well surprisingly the 33gtr has the same clutch as you *gasp*!
Npc sprung button clutch capable of supporting up to 650hp
$750.
/thread
$750.
/thread
Wow, i said "pull time" that sounds pretty dodgy :P
Ill definitely be looking at other options when it comes to the next clutch choice... SO FAR the cushioned button has been good, so hopefully it holds up.
To the OP, shop around as it seems there is plenty of options around ;)
Hey guys,
Sorry been so busy with work and getting my car sorted etc.
I ended up going the NPC Heavy duty Organic clutch, Rated to around 300rwkw this is plenty for what im going to use it for.
i got it all installed and parts (Inc Flywheel machining) And my coils changed while he was there, 4L of Redline lightweight shockproof for a grand total of $1360 (Inc clutch, labor, oils, maching of flywheel) Not bad if you ask me, im pretty happy with how i did, Now for fuel pump on the weekend, and then off to powertune on monday!
POWAHHHHHHHHHH!
Thanks to everyone who dropped their 2 cents worth, it was worth alot more to me :D
<3 SAU
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
