He's using Redline Lightweight Shockproof oil; it is blue in colour.
I recently installed an NPC 10" organic in mine; they rate this clutch to 300rwkw (I'm currently 250-260) and the pedal is half as light as the Exedy cushion button I replaced with it. Say goodbye to my left leg muscle! It does bite firmly when you get to that pick up point, though :)
Yeah the NPC feels as if it's broken, it's so light for a sports/race/enthusiast clutch. I honestly thought the fork slipped off the thrush bearing and I was shtting bricks.
So far it's pretty good, unfortunately the R33 I own now is stock (for now) so I can't really punish the clutch.
How do you like daily driving the button clutch? is that cushion button so you can have some slip with it?
I'm still tossing up between going their organic or button will only be putting out 270rwkw when tuned and car is mostly daily driven just when I do drift it I want to know kicking it won't be an issue. I also don't drive heaps or cop lots of traffic driving so I don't think a button clutch would be a major problem but do like drivability at same time cause i'm a big girl
Dont be crazy with it yet. I ran mine in for 1000km as suggested (no major clutch slipping or launches) and I dont know if it makes a difference but I'd rather listen to what NPC told me and follow their procedure
I dont know if mine felt THAT soft lol, think its a bit harder then stock but def nicer then the exedy
If you're drifting, an organic clutch is bit of a no no, you'll fry it. On my previous R33, I made about 250rwkWs and I toasted an organic within 1.5 years of owning it. I then moved to Exedy Sports Ceramic from a R32 GT-R, that lasted till I sold the car (probably still going strong), however it was crap to drive. Wasn't fun, especially with the stock slave, after upgrading to a larger Nismo item it felt better, but still not that great compared to this NPC clutch. It's very light, nearly as light as stock and more easier to slip and drive.
Saying that, I've always tend to just give it some revs and drop it to get the car going. I know it's jerky, but it's going to save me going under the car and do a clutch again on the floor.
Edited by johnnilicte
I have a 10" carbotic button clutch from NPC in my gtr. I never saw easy driving from day 1. Only time will tell how well it will last, but 5000km and its still going strong. I drive my car every day in stop start bullshit and there is no problem. Just use the friendly handbrake when on a hill. In these early mornings it loves to chatter and bite harder than when it warms up.
So far it has held 10 launches and many wot runs. I recommend them.
the reason the NPC clutches are lighter then other sport clutches is due to the 10 inch pressure plate and larger spring area.
i have a 180sx with an RB30e+t and NPC organic clutch with rb20 box... i drift it and clutch holds up well, that makes around 200 rwkw
I am going to give him a call to sugest something to hold 500kw dont know if i am looking at twin plate territory
Definitely twin plate territory.
Most of the Japanese twinplates won't even hold that much power for long due to them using tiny clutch plates
NPC sprung centre cushion twin is the way to go. Drives like a toyota hi-ace and will hold 1khp to the ground
Just an update, after 1 tank of fuel later the clutch feels much better.
I still am totally impressed with the pedal feel, but it is a tad bitey. I tried going up a car park ramp, I looked like a total idiot LOL
Yeah after a long drive yesterday mine is feeling so much better.
I just got a clutch from KB clutches in Sydney.
He was a really nice bloke that asked everything to do with the car and the power/rpm/use
Managed to pick something up for $410 including postage to ACT
Only time will tell if it holds up or not.
But I currently am pushing around 240-250rwkw
i got my 300 RWKW clutch from KB aswell, held out with no issues and came with few exeddy bits too, i paid 440 delivered to SA
Just an update, clutch seems to be more easier to drive or it just could be me getting used to it. Still need to chirp the wheels a tad getting up ramps when I'm stationary, but much easier than my old car with the Exedy Sports Ceramic.
Getting my NPC 10" carbotic clutch installed tomorrow. Will see how shit i am at launching it when the drags open up in a few months. Current excedy ceramic button lasted 2 years of every day driving, skidpan days, drag nights, clutch kicks, etc. This NPC one holds 450rwhp im told, so should keep me happy for a while!
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
