Had mine in for about 1000kms and love it. went to a track day last week and have a drag day at the end of the month. Do get chirps taking off sometimes if im at a complete stop, if i have a slight roll its nice and smooth taking off.
Clutch in, so far so good. Its acting like a twin plate at the moment, cant take off without spinning the wheels lol. The pedal is lighter somehow than the old excedy cushion button, which is awsome since the NPC carbotic is a much tougher clutch.
Only thing was the spigot bush that came with the NPC was 1mm thicker in ID so had to source another one.
You and your shimmed diff lol
Well 2 weeks of 360kw and my Excedy Cushion button shat itself :/ so I'll call NPC and see what they recommend for 400kw as that's my next stop lolz
was it the pink pressure plate Exedy or the silver plate? saying that the NPC one is crazy good, so good I feel sorry for my gearbox LOL
It was that long ago i cant remember.... It hasnt done many KM's but its been in there a while... i think it was pink, i know the plate was pink anyway....
For 400kw they will recommend a twin plate
Ghey! :(
I don't know why they would. Our NPC single plate 10" clutches are both holding 400-450rwkw happily for over a year now. Drag events, circuit racing. No problems.
We rate them up to 600whp before we suggest a twin plate is necessary
Yep, the pink ones are made here, they're pretty much just modified factory spec pressure plates as Jim Berry told me, he goes the Silver ones are from Japan and they're suppose to be more serious.
I've had the Silver plate before from a R32 GT-R with a 4-Puk Ceramic, did me well for over 1 years till I sold the car, wonder if it's still going strong with the 3rd owner.
Ah. I have that npc 10", but i swear the guy said it will hold up to 400kw and after that a twin plate is recommended. Maybe i miss heard.
It's possible that slight arse covering is being done there. Maybe they don't want to say they can do something and then have one guy prove them wrong.400wkw is getting close to where we've tested them up to so I'm guessing that would be why they would say that
This is what i want to hear! :yes:
I'm referring to the 5puk button variety btw. The organic we don't really push past 300rwkw
Yep just spoke to them about it, with modification he is confident it will hold the 400rwkw...... BUT it'll be a little pigish to drive daily :( anyone using one of these in a daily?
Hmmm thanks guys, will research all options but the guys at NPC seem to be the best in terms of knowledge etc so far :)
The button can be modified to hold 400kw so that should do!
I use mine every 3rd night? not too bad. I just drop it at around 1700rpm, I don't bother driving it smooth (clutch will last longer). Up the car park ramp at my gym is gold, there's a speed hump midway up. I usually just handbrake then chirp it over, people think I am retarded.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
