I use mine every 3rd night? not too bad. I just drop it at around 1700rpm, I don't bother driving it smooth (clutch will last longer). Up the car park ramp at my gym is gold, there's a speed hump midway up. I usually just handbrake then chirp it over, people think I am retarded.
Because race car :P
Sweet, thanks guys! More parts i didnt budget for...... Car has done 1500kms since tune and has killed coilovers and clutch so far, what next? (Nobody answer that, Flamin Mongrels) lol
done a few thousand on my Carbotic now Mat..2 track days..
Its no pig its a dream to drive man, you won't be disappointed at all
unless you prefer grumpy old man clutches...why anyone would want one or one of those crappy rattly metal things is beyond me.
.The NPC is all class
Its a dream to drive man you won't be disappointed at all
.The NPC is all class :D
Ah sweet! Thanks for that :D
Has it still got a good pedal feel etc? Apparently he said mine will be modified as ill aim for 400kw eventually.... :yes:
I slip my 10' NPC every time I take off, I know its not the best for the clutch but I'm 2 years in and its still showing no signs of slipping.
There a quality product thats for sure. I'll have a look at mine when the engine comes out of my car in the last half of this year.
Can always send it back for a rebuild anyway
I also did some calling around apparently confusing ppl when i called after matt had lol .... but i have the silver plated excedy comp clutch abd jim berry said its a good bit of gear and he can build it to handle 450kw + with a 10" or bigger something and solid centre carbon thingo ?? sounds good he built my mates cusco hyper angle and its amazing and handles all the clutch kicking he can thor at it withh 300 odd kw so might go down that path
LOL, i spoke to Jim for nearly 2 hours yesterday man!
He said they will be a pretty tough bit of gear, mine will be different specs to yours though as ill be on the road more than track :P
I got that Exedy Silver NC10T push pressure plate from a R32 GT-R if you want it, it's 1.1 tonnes
Problem is your GT-t is Pull not Push, unless you want to convert it to a push setup. Cheaper in the end.
  • 1 year later...
#strongbump
So yeah, I've had my NPC clutch for nearly 2 years, about 15 000 km & 3 track days..
It's starting to slip!
In 4th when you mash the pedal it will slip a little/shudder then bite & my friction point is quite high up. It engages in the last 1cm or so.
I think it's dead, maybe my mates have ridden it to death :(
How long has your NPC carbotic lasted?
I pulled my NPC when I did my engine change out. decided to get it rebuilt rather then having to pull the gearbox out later on if it started slipping. Have to say, the clutch looked great, no marks/hot spots etc on the flywheel or pressure plate and the friction material, besides being worn, looked great. Best looking clutch I've ever pulled out of a car. Could have gone back in but was running low on friction material so thought I'd start fresh
They were very helpful and quick rebuilding the clutch to. Sent it away Thursday I think, had it back on Tuesday or wednesday.
#strongbump
Mine should have been similar in design i guess and after 5000km it also looked brand new... I would go with Callans suggestion and just get a freshen up, its just new pads and a quick clean up most likely... Could be other causes for the premature wear though not necessarily the clutch itself, grease or oil contaminating it etc... Only way to know is to pull it out and have a squizz!
I ran 255rwkw for pretty much the whole time I had the clutch in, and I daily drive it and slip it on the street a fair bit. So I'd say if the wear on mine was excessive then it was to be expected. I dont think it was terribly worn but, should have measured how much material was left and compared to new.
The rebuild is basically a complete new clutch. The pressure plate I think was brand new and they just removed and replaced the pads on the clutch plate, must have checked the springs etc and the spline as well but this wasnt replaced (all looked good when I pulled it out so not suprised)
All up it cost me just shy of $500 with a new throwout bearing and express delivery, so while thats not 'cheap' its not to bad for a new clutch considering new ones are up near $800 now I think?
This is all my NPC gear reconditioned:
Edited by 89CAL
I'm just a little concerned about the premature wear, especially my car isn't make more than 200kW
Might pull out the box next weekend whilst I fit the new turbo :)
Yep good plan! There is no way its power related and it shouldnt wear that quick unless its been driven like shit...
Pull it out and report your findings :P
#strongbump
Just copper mix it and be done with it. If you did it in the first place you would have to pull the box out again! :P
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
