im gunna try, i wouldn't even have to take the car of the trailer :)
I've just about got my car ready log booking, but im not sure if it will be done by this date.
can i rock up with a caged, non-booked car?
https://www.sau.com.au/forums/topic/398520-wakie-19-may/#findComment-6333099
cheers, will do.
but before i go bothering them, do you need to be a member of one of the clubs?
Just spoke to Jonathon Graham (WRX guy) and he said as long as the car passes Scruit and you are a member of a CAMS affiliated club (SAUNSW) you are good to go.
You can pay by the link in the entry form, fill in the entry form and email it to Jonathons email address.
If you pay before 11 May cost is $165.
Mark
https://www.sau.com.au/forums/topic/398520-wakie-19-may/#findComment-6338574
  • 3 weeks later...
Did you have the Mines baffles in the 26 covers on?
Yes and it was 99% better, still had a small amount of slatter that got through the covers/baffles and catch can, only a couple of mills/drops though, I didnt drip down from the car to the track but it was still annoying.
To fix the problem Im going to get fabed up another catch tank which will be removeable or have a tap in it to drain it when it gets some in it, even after a full track day I think there would be no more than 10 to 20 mills in it.
The first session I just plodded around and it was fine, the second session I got up it a little bit more and that was fine, the third session I thrashed the bejesus out of it, changing gears when the shift light flashed and trying to keep it on the boil, thats when it spat a little.
Awesome fun day with a PB and big four wheel drifts, the Hankooks although only classed as a street tyre were great, no nasty moments with them at all even when doing four wheel drifts through the corners.
With a few more sessions under my belt I can smell single figures.
Ill fix up the little issue of the oil and give her some maintanance like new pads and stuff and then....
Come on Skyline Nationals.
https://www.sau.com.au/forums/topic/398520-wakie-19-may/#findComment-6362524
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
