I haven't been on here in quit a while so I though I'd reintroduce myself and my new R34 GTT
Names Adam, 26 and I'm from western sydney
I picked up my first Skyline last week and absolutely love it
Off the top of my head it's got a Nismo kit, Rays Lightweight rims, HKS turbo timer, HKS pod filter in a customer enclosure, PowerFC ECU, Bosh fuel pump. There's more but I'm drawing a blank at the moment (long day at work :) )
Currently pushing 206kw on 15psi
Handling will be the first thing that I'll be working on and maybe some interior cosmetic changes
I'm looking forward to learning a lot on this forum and heading out to some meet ups and cruises.
If anyone out west is up for a meet up or cruise I'm always keen
https://www.sau.com.au/forums/topic/398522-hi-from-sydney/
Thanks all
I'm debating whether to try and get the GTT wing for it or leave it as is
Also a list of mods:
Hks exaust cat back
Hks mushroom filter
Hks turbo timer
Door speakers n tweeters
Intercooler
Hpi turbo to cat exaust downpipe
Apexi PowerFc computer
DBA slotted rotators and heavy duty sports brake pads
Bosch fuel pump
Pioneer deck
Turbosmart boost tap
Heavy duty clutch
https://www.sau.com.au/forums/topic/398522-hi-from-sydney/#findComment-6331496
leave it without the wing.
definitely dont get a drift wing. yuck.
good luck with modifying.
just remember, there is heaps of amazing info on this forum regarding modifications, but there is also misleading advice too, so make sure you keep your wits about you!
https://www.sau.com.au/forums/topic/398522-hi-from-sydney/#findComment-6334811
  • 1 month later...
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
