Ok, I feel my GTS-T is feeling a little neglected so I'm considering a 100 hp shot of NOS on demand on WOT.
RB25/30 - GT3076R - Haltech Platinum 2000. 337 rwkw.
Good move ?, or should I save the dollars and wait until my kids pillage it all.
https://www.sau.com.au/forums/topic/398534-to-nos-or-not-to-nos/
I don't drag it.
I'm hoping for a setup which the Haltech can introduce Nos only in certain gears , revs and at WOT.
But right now my injectors are maxed , my intercooler has 2 1/2 in and out, and I'm running stock manifold.
Will I still get anything more with NOS ?
I don't drag it.
As long as your exhuast is up to the extra flow, yes you will see great gains. The stock intake manifold makes it easier to get a more even distrobution from single point of injection.
Your intake pipework etc wont affect the amount of extra power you can gain from nitrous.
The trick is to get the nitrous consistant. To do this you will need a bottle pressure gauge and heater on a pressure switch.
Is the engine still stock internally? If it is, I would suggest no more than 75ph fixed shot or 100hp progressive shot. If it's built, then think 100 fixed and 150 progressive, depending on boost pressure etc.
Cheers
Justin
Put a twin scroll 3788R on it instead!
I dont usually go for performance in limited quantities. Id prefer to know I can hoon interstate if I wanted to LOL
Le mans 24hr of Hoon
So get a G size bottle :woot:
Will lift the bonnet and intake manifold 10ft off the ground if it backfires though lol
Yeah... leanouts/nitrous backfires are pretty spectacular. Only ever seen them on carbied engines though... not saying it can't happen, but I've never heard of a backfire on a FI efi engine (engines that don't mix air and fuel inthe intake manifold 'plennum').
I think it's a great 'power adder'. There is no real trade off for the extra power when you'r not using it. For an extra 100hp of kick, you don't have to use a bigger turbo- more lag, you don't need bigger injectors- fuel economy/tune resolution, your not shifting the power curve up or down- if your using cams/cam gears, there's very minimal down time for install and it dosn't cost a bundle. Not to mention the dyno curve goes straight up at activation- ha ha ha!
Cheers
Justin
Thanks for all that info.
Yep car is built forged bottom end, Poncams, and Plazaman plenum.
Exhaust is stock ex manifold to 3 inch.
Intercooler has 2.5 either side.
3076 is 0.82 Ar, should have gone 1.06.
Running 21 psi now, does have more in it.
it does feel like its choking at high rpm
Edited by conan7772
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
