Ok, I feel my GTS-T is feeling a little neglected so I'm considering a 100 hp shot of NOS on demand on WOT.
RB25/30 - GT3076R - Haltech Platinum 2000. 337 rwkw.
Good move ?, or should I save the dollars and wait until my kids pillage it all.
https://www.sau.com.au/forums/topic/398534-to-nos-or-not-to-nos/
I don't drag it.
I'm hoping for a setup which the Haltech can introduce Nos only in certain gears , revs and at WOT.
But right now my injectors are maxed , my intercooler has 2 1/2 in and out, and I'm running stock manifold.
Will I still get anything more with NOS ?
I don't drag it.
As long as your exhuast is up to the extra flow, yes you will see great gains. The stock intake manifold makes it easier to get a more even distrobution from single point of injection.
Your intake pipework etc wont affect the amount of extra power you can gain from nitrous.
The trick is to get the nitrous consistant. To do this you will need a bottle pressure gauge and heater on a pressure switch.
Is the engine still stock internally? If it is, I would suggest no more than 75ph fixed shot or 100hp progressive shot. If it's built, then think 100 fixed and 150 progressive, depending on boost pressure etc.
Cheers
Justin
Put a twin scroll 3788R on it instead!
I dont usually go for performance in limited quantities. Id prefer to know I can hoon interstate if I wanted to LOL
Le mans 24hr of Hoon
So get a G size bottle :woot:
Will lift the bonnet and intake manifold 10ft off the ground if it backfires though lol
Yeah... leanouts/nitrous backfires are pretty spectacular. Only ever seen them on carbied engines though... not saying it can't happen, but I've never heard of a backfire on a FI efi engine (engines that don't mix air and fuel inthe intake manifold 'plennum').
I think it's a great 'power adder'. There is no real trade off for the extra power when you'r not using it. For an extra 100hp of kick, you don't have to use a bigger turbo- more lag, you don't need bigger injectors- fuel economy/tune resolution, your not shifting the power curve up or down- if your using cams/cam gears, there's very minimal down time for install and it dosn't cost a bundle. Not to mention the dyno curve goes straight up at activation- ha ha ha!
Cheers
Justin
Thanks for all that info.
Yep car is built forged bottom end, Poncams, and Plazaman plenum.
Exhaust is stock ex manifold to 3 inch.
Intercooler has 2.5 either side.
3076 is 0.82 Ar, should have gone 1.06.
Running 21 psi now, does have more in it.
it does feel like its choking at high rpm
Edited by conan7772
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
