Ok, I feel my GTS-T is feeling a little neglected so I'm considering a 100 hp shot of NOS on demand on WOT.
RB25/30 - GT3076R - Haltech Platinum 2000. 337 rwkw.
Good move ?, or should I save the dollars and wait until my kids pillage it all.
https://www.sau.com.au/forums/topic/398534-to-nos-or-not-to-nos/
I don't drag it.
I'm hoping for a setup which the Haltech can introduce Nos only in certain gears , revs and at WOT.
But right now my injectors are maxed , my intercooler has 2 1/2 in and out, and I'm running stock manifold.
Will I still get anything more with NOS ?
  On 25/04/2012 at 9:18 PM, conan7772 said:
I don't drag it.
As long as your exhuast is up to the extra flow, yes you will see great gains. The stock intake manifold makes it easier to get a more even distrobution from single point of injection.
Your intake pipework etc wont affect the amount of extra power you can gain from nitrous.
The trick is to get the nitrous consistant. To do this you will need a bottle pressure gauge and heater on a pressure switch.
Is the engine still stock internally? If it is, I would suggest no more than 75ph fixed shot or 100hp progressive shot. If it's built, then think 100 fixed and 150 progressive, depending on boost pressure etc.
Cheers
Justin
  On 25/04/2012 at 11:52 PM, XRATED said:
Oh and FYI- Nitrous is an inert (not activly flamable by itself) gas and won't lift your car 10ft off the ground...
Will lift the bonnet and intake manifold 10ft off the ground if it backfires though lol
  On 26/04/2012 at 2:58 AM, GTScotT said:
Put a twin scroll 3788R on it instead!
I dont usually go for performance in limited quantities. Id prefer to know I can hoon interstate if I wanted to LOL
Le mans 24hr of Hoon
So get a G size bottle :woot:
Yeah... leanouts/nitrous backfires are pretty spectacular. Only ever seen them on carbied engines though... not saying it can't happen, but I've never heard of a backfire on a FI efi engine (engines that don't mix air and fuel inthe intake manifold 'plennum').
I think it's a great 'power adder'. There is no real trade off for the extra power when you'r not using it. For an extra 100hp of kick, you don't have to use a bigger turbo- more lag, you don't need bigger injectors- fuel economy/tune resolution, your not shifting the power curve up or down- if your using cams/cam gears, there's very minimal down time for install and it dosn't cost a bundle. Not to mention the dyno curve goes straight up at activation- ha ha ha!
Cheers
Justin
Thanks for all that info.
Yep car is built forged bottom end, Poncams, and Plazaman plenum.
Exhaust is stock ex manifold to 3 inch.
Intercooler has 2.5 either side.
3076 is 0.82 Ar, should have gone 1.06.
Running 21 psi now, does have more in it.
it does feel like its choking at high rpm
Edited by conan7772
  On 28/04/2012 at 3:41 AM, NYTSKY said:
IMO you only need it to bring on a big turbo. If you want more power add more boost. If you cant because something is maxxed then you dont want to add nitrous to it.
I think mine turned off at about 5000rpm
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
