Hey Guys,
Putting up an expression of interest for this beast.
Since I bought it a year ago, I have fixed a few things on it and bought a few parts. Not only that, for NSW people, I have gone through the headache of getting it blue slipped in nsw.
Funnily enough, z wife does not want me to sell it as she drives it the majority of the time, but I want to atm due to a shortage of money, moving, renovating, not wanting to lose my license (drive for a living).
I have had so much fun in this beast over the last year, a true tough jdm car with the looks and power to match. Never been hassled by the cops, only pulled over once and fined for speeding after opening z gate in front of them..woops! Not asked to pop the bonnet by highway patrol either.
Here are the details;
2JZ-GTE
Silver
Sunroof
5 Speed manual conversion
R154 Gearbox
Nicks Performance button clutch ( custom made for the car rated 750hp ) Needs some adjustment.
Custom tail shaft
Torsen LSD
HSD Base height coilovers
Work BRIII wheels 19x9 +30 19x10 +33 (camber wear on rear tyres)
Garret T04Z 1.00 rear housing/ twin scroll
Generic Manifold (have twin scroll manifold to go with it for advertised price)
50mm Waste Gate (diaphragm leaking I think)
Custom oil and water lines
3.5inch dump pipe and exhaust into 3inch HKS cannon
Custom intake
HKS air filter
HKS 264 degrees cams ( exhaust and intake )
HKS cam gears
HKS timming belt
Sard 800cc injectors
Bosch 044 Fuel pump
VIPEC V88 Standalone ECU - *NEW*
Greddy Profec B 2 Boost Controller
New Radiator
Subaru Thermo Fans
Supra water pump
Intercooler with custom piping (needs one rubber hose replace due to scrubbage)
Custom made wastegate pipe, can vent to atmo or plumb back at will.
No Oil leaks.
Body is okay for a 93 model. Slight fade on roof, couple of lil pin dints in doors, slight dent on front guard (which could pop out)
Pinoneer 7inch DVD Player, iPOD ready
1000watt Panasonic amp
12inch Alpine s type
LED light kit (Dash, Climate Control, footwells, doors)
Nardi Deep Dish Steering Wheel
TRD gear knob
Tinted Windows
M3 Boot Spoiler
s2 cup holders
CAM201 Alarm system - Keyless Entry, Immobiliser, Alarm - **NEW**
Last dyno results are: 354 rwkw (475bhp) @ 19psi. With alot more potential.
Registered in NSW till feb 16 2013 (Mod plate/engineers for QLD)
$17k now registered...I may add, that I mostly want the money but will entertain offers for SUV/4WD/Van's or anything not fast/low and family orientated.
0415 306 457 (shift worker prefer pm or email) call between midday to midnight.
[email protected]
Located; Sydney West, NSW
Feel free to contact me and talk it over.
Some crappy phone pics, p plates were my wifes.
  • 3 weeks later...
Will be getting 4 new tyres in the coming days and will take offers on original price.
Also looking for a swap. Can be almost anything of interest, just not heavily modified like the risto.
  • 2 months later...
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
