I've recently sold my WRX, and we're back to just having our little Pulsar.
Now I'm working in the mines, my budget has slightly increased for our next car.
I was pretty set on buying a Stagea, but now I have seriously been thinking about a EVO 7.5 GT-A.
They are described as being a mix of sports and luxury. Are they just an EVO 7 with different interior, and auto box?
How interchangeable are parts between EVO 7 and the GT-A?
Any one had a drive of one?
Here are some on car sales i was perusing.
http://www.carsales.com.au/private/details/mitsubishi-lancer-2002-10948242?base=1216&vertical=Car&Range=Price:Min,Max~0.5&page=1&eapi=2&sort=Price&cr=6&__N=1246%201247%201252%201282%204294964597%204294966896%201216&silo=Stock&find=evo%207%20gt-a|CarAll
http://www.carsales.com.au/private/details/mitsubishi-lancer-2002-11407417?base=1216&vertical=Car&Range=Price:Min,Max~0.5&page=1&eapi=2&sort=Price&cr=7&__N=1246%201247%201252%201282%204294964597%204294966896%201216&silo=Stock&find=evo%207%20gt-a|CarAll
Cheers adam
https://www.sau.com.au/forums/topic/398566-mitsubishi-evo-75-gt-a/
That first one is running 20psi, Im no evo expert but is that fairly high???
yeah it is i guess. to be honest it was just a quick example off carsales for they guys who hadn't seen one before.
Nah them are WRXs run stupid levels of bost compared to skylines.
true, my old rexy ran 21psi on high boost.
Very small fuel tank
I was looking @ 1 a while ago & this put me off
really? i spose they like to drink it pretty quick too
i had a mate who is a mad evo fanboy describe them to me as 'the biggest money pits out of all the evo's'.. not sure how correct this is or not.
i drove one awhile a go i was looking at buying. bloody nice to drive and a goes well in standard form. yes the tank is a bit small but you work around it. i like the benefit of the auto with the EVO running gear.
fairly snappy if you are up it. had a couple of them.
i know next to nothing about the reliability of EVO's. would you say the the 'money pit' advice i was given was anywhere near correct?
if its virigin and you simply intend to drive it - I would say it will be fine. if you start fiddling with it - yes it will become a money pit very quickly. nothing seems to happen with these until you hit about 4k then its gone.
The GT-As run a slightly smaller turbo which gives it a fatter midrange with less top end. It works really nicely with the auto and short-shifting second-third out of corners is an awesome feeling. They came with a wide variety of options (i.e Recaro front seats are optional, as is the regular Evo 7 rear wing) and a number of colours that were never available in the regular Evo 7s, so make sure you look carefully at what you're getting. It's fairly common to switch to the Evo 8 MR factory turbo (or even the normal Evo 7 turbo), as they can easily handle 22psi for daily use.
The tiptronic box, however, is prone to overheating, and replacing/repairing it is where the expense comes in. Basically, get a trans cooler if you plan to do any mods to the motor.
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
