Ok so I was wondering if a fudged coilpack would cause a car to fluctacte at idle (1200 to 2000rpm) I cnt find any vac leaks and I jst went to go down the road and my car started hesitating and almost died at stand still, Managed to limp the car back home, I've had it on diagnostics and it comes back afm, I changed afm and still did the same thing, I've got new plugs in gapped at .8mm, cnt find any vac leaks, tps is fine, I've had 2 mechanics look at it quickly but have no idea.. I'm going to take it to 999 automotive tomorrow, but after I jst took it for a drive I was thinking maybe the coilpacks r the problem, the car is upto 137xxxkms, 3" exhaust turbo back, nd running 12psi, r34 gtt sedan..
https://www.sau.com.au/forums/topic/398592-coilpacks-shot/
As many as it takes to fix my car... Gotta learn somehow and As I've never had this problem
B4 I'm trying to find out as much as I can so I know what to do in future, as I've tried everything else, and as no1 has said anything about coilpacks I wanted to put it in the title to attract other people that have had coilpack issues to share with me there problems as I dnt know the symptoms and I dnt know how often ur suppose to change them as there is mixed info on them? This is a forum after all for getting information?
https://www.sau.com.au/forums/topic/398592-coilpacks-shot/#findComment-6330505
Check engine light is on, traction control is stuck on as wel as I snapped a nipple pulling a vac hose off on the traction control sensor but is getting replaced tomorrow, this all happened b4 that but, I did do a diagnostics and it came back afm
So I
Replaced it, didn't fix it and I was told that Rbs are common to throw afm codes in when something is wrong... I'm going to let aechanic sort it out so if some1 else knows a gd mechanic near sunnybank I will take it there otherwise 999 is my option for now
https://www.sau.com.au/forums/topic/398592-coilpacks-shot/#findComment-6330614
Should of wrote that more clear, but I snapped the nipple looking for vac leaks after the problem
Accured but that def is not the
Problem, unsure if the engine light came up after I snapped the nipple or because the car is now starting to hesitate
https://www.sau.com.au/forums/topic/398592-coilpacks-shot/#findComment-6330617
I'm not that stupid mate.... Like I said I jst need a good mechanic, I've tried everything that I have Bn told to do off this site, quite over it now cos it's my daily driver...
I don't think jez was implying that you were as dumb as a door knob.
More the fact, did it come off a car where it was working fine?
https://www.sau.com.au/forums/topic/398592-coilpacks-shot/#findComment-6331133
