Wrecking 1992 R32 GTST, previously registered, full URAS body kit, paint has a slight fleck/glitter, good for a re-shell, flared rear guards. Shell will be for sale, price will depend on what's left on it and what you want included. drp me a pm.
110,000KM R33 Series 2 RB25DET, tested before install by previous owner with good compression on all cylinders. It's believed to be internally stock. Has had timing belt done $900 (long motor)
R33 5-Speed Box – includes hd clutch $1200 or $1400 with the tail shaft and conversion for an r32 gts
Haltech Sprint 500 Platinum computer with unmolested lead kit $700
GTR Injectors $250
gtr head lights $200 for the pair
Aftermarket GTR Fuel Rail $100
Polished front facing intake (china spec) $150
Bigger throttle body $100
Big front mount intercooler kit with Turbosmart bov, TIG welded stainless piping (everything included) $300
Oil filter relocation kit $250 new
High mount stainless exhaust manifold, T04Z turbo, braided oil lines (needs water lines) $1200
Full 3" stainless exhaust with single Genie canon $300
Big alloy radiator $200, matching thermo fans $120
"Carbon fibre" look GTR style fibreglass bonnet $450
"Carbon fibre" look front grille $130
LED Tail lights $150
Smoked Reverse lights $120
HICAS removal lock bar $100
HSD Coilovers very good condition $600
Standard reshimmed LSD $300
R32 GTR seats $450
Turbo timer $30
adjustable upper control arms $250
Nismo control link set including castor rods, upper control arms and lower arms $500
Front strut brace $110
Rear strut brace $80
Everything on the car is for sale, so if its not pictured just ask and I will most likely have it.
pm me for anything you want
  • Replies 121
Fatz what cond are the headlights in?
want some with no chips/sand blasted glass, good reflectors inside, all rear mounts attached.
Price posted to melb? Otherwise i think Roy is in Sydney... wonder if that guy can bring them back to me
would have to have a decent look at them and pull them off
postage would be 30 bux
located ower blue mountains sydney
give jennas number a call if you want something as she is home all the time, knows what we have and ships everything (in between nappy changes)
pete (jennas number is 043189159)
Geeeeeeenuine T04Z Pete?
What rear housing, twin or single entry?
Cheers
the guy i bought it off said it was a garret but can't confirm until i pull it off and check
rear housing is a 0.88
id be keen for that setup since my td06 is out of puff but looks china spec. Exact same one on ebay for less than $600
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
