Wrecking R32 Gtst Heaps Of Cool $Hit Sydney
  • Replies 121
hey mate, if the head lights are still for sale can u text me on 0400750335. thanks
it had 32 gtr lights not gtst ones.... they are sold but i have another set coming in a few weeks
A/C lines?
no ac lines
Pics of oil relocation kit?
it's actually just an oil cooler kit so cooler, engine adaptor and oil lines $200, let me know if you still want pics
  • 3 weeks later...
Righto, the shell has now gone to the scrap yard but I have the following stuff left:
Oil cooler with hoses and adaptor (not in pic) $150
High mount stainless exhaust manifold, T04Z turbo, braided oil lines (needs water lines) $850
Full 3" stainless exhaust with single Genie canon, excellent condition $250 (can get better pics than this if required)
carbon look air guide $30 (has a slight bend but still ok)
Reverse lights $60 pair
HICAS removal lock bar $90
Aftermarket GTR Fuel Rail $100
Front strut brace $110
adjustable upper control arms $100
Genuine Nismo control link set including castor rods, upper control arms and lower arms $500
Veilside gearknob $40
M's turbo timer $30 delivered
SABRE smoked gauges $20 each -Oil temp, Oil pressure, water temp incl sensor, each one comes with a mounting cup
URAS rear bar $150
URAS side skirts $100
Front guards $100 pair
Boot with no wing or holes $100
Doors $50 each
Door cards $20 each, will not ship as its a pain in the arse for very little money
  • 4 weeks later...
Sorry everyone haven't checked this thread for a while, replies below:
Hey fatz, you got any other turbo's lying round to suit RB20? Something a little smaller then that monster? Cheers. Also the istrument cluster aswell.
nah no other turbo kits at the moment mate, was it the speedo cluster for gtst you need? If so then yea i have it... 50 bux, has a white background, pm me if you want it :)
have u got pods
no pods
I'll take the forward facing intake + throttle body.
Text 0433046838
already sold mate
dibs on the front adjustable control arms if I buy myself a 32 this arvo... might need other bits too
yea pm me if you want them/anything else
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
