  • Replies 121
hey mate, is the Polished front facing intake still up for grabs?
lowest price with postage cost to Tas 7315?
It's still here but someone has a deposit on it
First in with the cash I say but I'll check if he's picking it up anytime soon
front hubs/knuckles? post to gold coast?
200 plus whatever shipping is... probably around 70 bux or so. Pm me if you're still keen
is the bonnet still fs?? and is it adr approved???
bonnet is sold
  • 3 weeks later...
Here's an update of what's still for sale:
Aftermarket GTR Fuel Rail $100
Oil filter relocation kit $250 new
High mount stainless exhaust manifold, T04Z turbo, braided oil lines (needs water lines) $1200
Full 3" stainless exhaust with single Genie canon $250
Reverse lights $100
HICAS removal lock bar $100
Standard LSD $200
Turbo timer $30
adjustable upper control arms $250
Nismo control link set including castor rods, upper control arms and lower arms $500
Front strut brace $110
Heaps of panels and a registerable shell, pm me for prices etc
Sold stuff:
-front reo
-front bar
-headlights and LED tail lights
-indicators
-front carbon grille
-Haltek and injectors
-front body loom
-headlight switch and surround
-gearboot surround and plastics
-drivers demister vent
-aircon controller
-Gtr seats
-rad top mounts, bonnet bolts etc
-windscreen wipers front and rear
-Rear strut brace
-HSD Coilovers
-front brakes
-Motor and gearbox
-Plenum
-LCAs
-alloy rad
-intercooler and piping
-Bosch pump
Hey buddy, have u still got the centre vent and passenger aircon vent? And the ashtray. Price posted to melb 3038 please !
will double check and let ya know tomorrow.... was it the front ashtray or the rear one in centre console?
have a perfect condition centre vent, they are like hens teeth and not cheap to buy so 130 posted
Pics of some extra stuff I found.....
Rb25 clutch incl flywheel in good nick $50
Adjustable camber arms $100
Stock LSD $100, could possibly do with a rebuild
Crappy turbo timer $20 posted
SABRE smoked gauges $20 each -Oil temp, Oil pressure, water temp incl sensor, each one comes with a mounting cup
Door cards $20 each, will not ship as its a pain in the arse for very little money
SAAS steering wheel and gearknob $130 for both, gearknob is like new
Veilside gearknob $40
URAS rear bar $150
URAS side skirts $100 pair
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
