has a few left from the GB, so interest buyer pls be quick! :D
CARBING Induction box:
http://www.okuyama-go.to/products/in_ex/in...intake_01.shtml
aluminium made, top quality
will fit R33 and R34. (not GTR)
$175
the plastic of clear top is extra $20
if u don't want the clear top, i can either
leave the hole there / not cutting the hole
interest buyer pls PM me
https://www.sau.com.au/forums/topic/39862-carbring-style-cai-box-195-posted/
Does this box suit both standard and aftermarket intercooler pipes on R34 GTT? [i have standard pipes on for now].
Will it also fit around the Blitz SUS Pod [stainless steel one], as it is quite big - bigger than A'pexi.
Thanks.
it will fit both aftermarket pipe stock pipe.
i used to fit a HKS's in mine which is similar size as blitz and no problem at all
muz, u got PM
Thanks.
OK, one last question: is it actually a sealed box or more like a cover? I cant tell from the pics whether it has all sides + a bottom to it? Actually it looks like there is no bottom to it in the 2nd pic... I really want to make sure that it shields the heat effectively!
I am very to keen to buy one but would like to know what I am getting before asking you to post one over, anyone in Vic already got one of these I can have a look at?
Thanks again!
Nismo R34
I have just bought one, and just fitted the Perspex cover as well.
I'm about to fit it this week sometime.
I'm happy to show you mine..... (if you show me yours.... eeeew)
Wouldn't have a stock clutch lying around would you?
PM me for mobile number
BASS OUT
  • 4 weeks later...
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
