Hey I'm doing RB25 S2 swap in my R32
I'm keeping the R32 wiring harness and the TPS/throttle valve swith connectors are differents on the s2 engine.
Can anybody give me wiring colors or TPS and throttle valve pinout??
Edited by lowexr
  • 6 months later...
Finally found some info, been searching for awhile now!
I'm using a RB20 loom and RB20 ECU (Nistune) and swapping in the S2 RB25.
Tonight i tried to remove the TPS from the RB20 to check it out / mock fit it to the RB25 and i couldn't get it off. Didn't pull very hard but it seemed rather connected to the throttle body.
Will the entire RB20 TB fit on the 25? or are we swapping just the sensor? If so is there any information on this? :)
Does that work? I removed the RB25 TPS and it looks rather different inside, aka it has a mechanical mechanism or lever that moves with the throttle body which turns the SENSOR.
I coulnd't get my RB20 TPS off.. but from images it looks rather different. It looks like it will bolt there... am i missing something? How does the 20 TPS work? airflow?
Sounds like you've got a S2 RB25, you can't switch the RB20 TPS over to the S2 RB25 throttle body.
You'll need an RB25 Series 1 throttle body, the RB20 TPS will bolt straight on.
I'm not sure if the TPS share the linearity, You may be able to wire in the RB25 TPS.
TPS work by sending a 0-5V signal to the ECU. The voltage sent to the ECU depends on the amount the throttle is open. 0% = 0.5V approximately, 100% = Close to 5V IIRC.
Darn, ok well if i was to get a S1 Throttle body.. does anyone know if that will bolt on? (i've tried searching..)
Also my RB20 tps plug goes on the S2 RB25 TPS top plug .. both 3 pin. Anyone know if that will work haha?
I've heard one is for the auto.. is it top or bottom?
Easiest thing to do is send the ecu back to NIStune, they will rewrite the base image to suit the rb25 TPS.
The rb25 tps can be fitted to rb20 TB but have to change the shafts over and a few other niggly things.
Its easier to wire in the rb25 tps and base image
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
