carsales link for more info
$32,000.
Here is the specification of the car, please have a look.
Engine and Driveline:
- EVO 8 bottom end (short block)
- ARP Headstuds and brand new OEM headgasket
- GTpumps td06-20g turbo
- EVO MR Blow-off Valve
- Brian Crower 272degree intake&exhaust camshafts
- Brian Crower adjustable cam gears
- Gates racing timing belt
- Gates racing balance belt
- Gates racing alternator belt
- Precision 1200cc injectors
- HKS EVC VI Electronic Boost Controller
- Exedy twin plate clutch + braided clutch line
- HKS Silent Hi power cat back
- Invidia dump pipe
- TurboXS front pipe
- Magnaflow 3" metal cat
- Walbro GSS342 500hp 255lt/hr fuel pump
- HKS Racing Suction pod intake
- x3e 52mm alloy radiator
- 1.3bar radiator cap
- NGK Super Power Cables ignition leads
- NGK Iridium BPR7EIX spark plugs
- Pivot Raizin volt stabilizer
- Pivot Super Earth grounding kit
- Beatrush radiator cooling panel
- Blox billet engine mount
- Engine torque dampener
- ETS Version 2 Lower Intercooler Pipe
- Reflashed ECU (dual map e85 / 98ulp)
Handling and Braking:
- BC type ER coilovers with external reservoir
- Whiteline 22mm adjustable rear sway bar
- DBA 4000s slotted rotors front and rear
- Ferrodo DS2500 front brake pads
- x3e rear brake pads
- Goodridge braided brake lines
Interior:
- Alpine CDA-9853 head unit
- Focal 165 CV1 speakers
- APEXi Full auto turbo timer
- Trust shift knob Type N
- Fixed in-car camera mounts
- CAMS Approved 1kg fire extinguisher with fixed racing mount
- Carbon fibre wrapped interior panels, stereo surround, window switches
- Black faced boost gauge
- 52mm Autogauge Oil Pressure gauge
- 52mm Autogauge Oil Temperature gauge
- 52mm Autogauge Water temperature gauge
- Evo 9 Steering wheel
Exterior & Cosmetics:
- EvoXenon's Custom Headlight & Projector
- HKS inspired front lip
- OEM Evo 9 rear bumper with OEM tow hook cover
- Voltex genuine CF rear diffuser
- Chargespeed side skirt extension
- Carbon fiber boot lid lip
- Carbon fiber vortex generator
- Zaklee Corp clear cam pulleys cover
- Repainted valve cover
- XXR 527 17x9.75 +25 in matte bronze
- 255/40/17 Bridgestone Potenza RE001
- D1 Spec racing lug nuts
PS. My best contact methods are SMS and Emails as I do not pick up calls at work.
0433552745
[email protected]
Cheers,
Gerald.
  • 3 weeks later...
  • 3 weeks later...
