carsales link for more info
$32,000.
Here is the specification of the car, please have a look.
Engine and Driveline:
- EVO 8 bottom end (short block)
- ARP Headstuds and brand new OEM headgasket
- GTpumps td06-20g turbo
- EVO MR Blow-off Valve
- Brian Crower 272degree intake&exhaust camshafts
- Brian Crower adjustable cam gears
- Gates racing timing belt
- Gates racing balance belt
- Gates racing alternator belt
- Precision 1200cc injectors
- HKS EVC VI Electronic Boost Controller
- Exedy twin plate clutch + braided clutch line
- HKS Silent Hi power cat back
- Invidia dump pipe
- TurboXS front pipe
- Magnaflow 3" metal cat
- Walbro GSS342 500hp 255lt/hr fuel pump
- HKS Racing Suction pod intake
- x3e 52mm alloy radiator
- 1.3bar radiator cap
- NGK Super Power Cables ignition leads
- NGK Iridium BPR7EIX spark plugs
- Pivot Raizin volt stabilizer
- Pivot Super Earth grounding kit
- Beatrush radiator cooling panel
- Blox billet engine mount
- Engine torque dampener
- ETS Version 2 Lower Intercooler Pipe
- Reflashed ECU (dual map e85 / 98ulp)
Handling and Braking:
- BC type ER coilovers with external reservoir
- Whiteline 22mm adjustable rear sway bar
- DBA 4000s slotted rotors front and rear
- Ferrodo DS2500 front brake pads
- x3e rear brake pads
- Goodridge braided brake lines
Interior:
- Alpine CDA-9853 head unit
- Focal 165 CV1 speakers
- APEXi Full auto turbo timer
- Trust shift knob Type N
- Fixed in-car camera mounts
- CAMS Approved 1kg fire extinguisher with fixed racing mount
- Carbon fibre wrapped interior panels, stereo surround, window switches
- Black faced boost gauge
- 52mm Autogauge Oil Pressure gauge
- 52mm Autogauge Oil Temperature gauge
- 52mm Autogauge Water temperature gauge
- Evo 9 Steering wheel
Exterior & Cosmetics:
- EvoXenon's Custom Headlight & Projector
- HKS inspired front lip
- OEM Evo 9 rear bumper with OEM tow hook cover
- Voltex genuine CF rear diffuser
- Chargespeed side skirt extension
- Carbon fiber boot lid lip
- Carbon fiber vortex generator
- Zaklee Corp clear cam pulleys cover
- Repainted valve cover
- XXR 527 17x9.75 +25 in matte bronze
- 255/40/17 Bridgestone Potenza RE001
- D1 Spec racing lug nuts
PS. My best contact methods are SMS and Emails as I do not pick up calls at work.
0433552745
[email protected]
Cheers,
Gerald.
  • 3 weeks later...
  • 3 weeks later...
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
