Have the following parts lying around from various builds, pics / prices below...
Contact: via PM or txt 0412 866 054
Can post at buyers expense however local pickup is preferred. Will be in Syd this weekend if anyone up there wants anything.
1: RB30 Pacemaker 3>2>1 Extractors.
Suits AUS R31, bolts straight to std exhaust. Used but good condition.
$100.00
2: Whiteline 27mm Front Swaybar
Suits front of AUS R31, as per pic - BYO link pins and bushes. Rub marks from tyres at full lock but otherwise good condition.
$110.00
3: RB30 Throttle Cable
Suits AUS R31, used but good condition.
$15.00
4: Solid Alloy Steering Bush
Trial Fitted but not used, as new condition.
$15.00
5: RB26 Laser-cut head flange
Purchased to make turbo manifold but ended up buying one to save time, as new condition.
$80.00
6: RB30 Top Gun Ignition Leads
$30.00
7: K&N Pod Filter
Suits 3" (75mm) pipe, used but good condition (just washed).
$30.00
8: KKR 2.5" (63mm) x 600mm Silicone Joiner
Surplus, brand new still in plastic.
$20.00
9: R33 GTS-T Rack Ends (STD)
Purchased brand new R33GTS-T rack from Pedders however had to change to different rack ends as it was going in an R31, as new condition.
$60.00
10: JJR480 Turbo
T3 flange, V-band Exhaust housing. New - trial fitted but never run, in original box with t3 gasket, banjo bolt etc. Suit RB20, RB25, RB30 etc.
$620.00
11: 4" (100mm) 45Deg Aluminium bend
Surplus, as new, purchased from GCG. As per pic - raw alloy.
$50.00
12: RB30 Engine Fan clutch
$15.00
13: R31 AUS S3 Front Grill
Used, no broken bits, was painted black yrs ago with a pressure pack so needs a clean up.
$20.00
  • 4 weeks later...
  • 3 weeks later...
  • 2 years later...
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
