Heh, figured that would get your attention :)
Just for curiousity's sake mostly - I'd be interested in any info relating to serious n/a RB buildups, whether they be 11000rpm RB18DEs, RB36DE strokers, what have you - has anyone here built up a hardcore n/a RB engine, or know of websites, a friend's cousin's brother-in-law's dog's vet's car, whatever you know, post it up! (but especially interested in stroked "big-blocks")
Cheers
J
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/
Cheers
J
With the help of a lot of people, I went through the exercise a couple of years ago and found the result, totally untractable, as it wouldn't idle under 3000 revs.
Firstly, the RB30 has a non balance related HARMONICS problem at about 7500 and to go higher, which was necessary to attain the HP required, it is necessary to push through 7500 ASAP.
My goal was 300+ rwhp. And special things had to be done and cubic inches isn't the answer.
We had an RB30 block, bored 1mm o/size, RB26 crank and rods, for optimum rod ratio for high reving n/a engine, RB26 head and induction system, including 6 throttle bodies. Capacity 2760cc. 600cc injectors, Z32 AFM, Q45 throttle body, custom extractors, custom forged pistons 13.5:1, Inlet cam over 350 degrees, exhaust cam about 340 degrees and at 10700 rpm we had 342 Kw at the fly.
Our decision was to scrap the plan as it was impossible to drive this on the road and we went TURBO.
Cheers.
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-816448
RB26 rod: 120mm?
RB26 crank: 73.7mm
RB30 rod: 154mm
RB30 crank: 86mm
Add the fact the RB30 block is ~1 inch taller and by using RB26 rods + crank in an RB30 block you've got a piston sitting ~40mm down in the bore at t.d.c.
That's one massive piston you'd have to use...
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-816901
dont post bullshit titles :D.
Thought it should've been obvious :rofl:
id love to see a 300kw+ na RB tho.
-rb25
Same 'ere. So it sounds like big inches are not the solution - I guess one would have to start with an RB26 then. Wasn't there an RB26DE Nissan factory race engine a while back?
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-820832
Forced Induction does mean waiting for a turbo to spool... what about a super-charger?
instant power, but nothing up top.
hardly true about nothing up top.
Depends on blower matching more than anything else.
And the type too.
I'd be interested to see anyone even create an RB36 ROFL.
And how cant an RB30 rev out past 7500?
There are too many RB motors that i can think of that go past this without a drama.
Some twin cam (26head) some not (sohc)
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-821985
For non-forced induction.. you'd really have to an 8 to have any form of driveability.
i think the M3 does pushes the envelope for a 6cyl at pushing out 252kw.. Some of the best figures for a naturally aspirated 6cylinder I can think of. With some work probably 300kw. So just get an m3 engine and put them, i'm sure its an easy task :)
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-822131
don't get me wrong, a well tuned turbo car has plenty of response too... mine does :)
but the response of an NA car is relatively linear, even with systems like BMW's VANOS, Honda's VTEC, Toyota's VVTL-i, etc., and you can experience a different way of attacking corners. that's what I miss most about NA cars :rofl:
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-822513
i think it would b VERY hard to get the m3 to do any more than it does, as all its components are built for power, unless u added nos or forced induction, same goes for the s2000. as for the skyline, rb30 bottom end, gtr head, port, cams, exhuast, pod in box with CAI, comp, tune, would go along way
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-829075
if its still using basic valve timing its going to get to a point where you just can't get much further without killing the driveability at some point.
Don't know about the beamers, but bit of stuff I know can be done with the s2000 to give it more kick. Everything comes out of the factory for all conditions, all fuel quality, economy, etc.
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-829135
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
