Guys and Gals,
Just after video info, I have volume 1 of Initial D (yes it all about an AE86) and would like to increase my video collection but Im finding it difficult to get, let alone only who stocks other volumes :) . Can anyone tell me where I can get the complete set or other volumes of this great DRIFT :flamed: video set. Cheers :)
https://www.sau.com.au/forums/topic/39874-initial-d/
new initial D is very good :rant: stage 4, there will be a wrx, r34 , s15 :cheers:
Erick Mate,
Can you tell Im about to ask a favour hehehe. What series have you got and are they in a format that can be copied. Ive got to look at the other sites that have been mentioned here but would always ask mates first. :)
https://www.sau.com.au/forums/topic/39874-initial-d/#findComment-818991
how did u guys get ur hands on Stage 4?
With subtitles?
only the first 2 episodes are floating around on the net at the moment.
the broadcast schedule in japan is as follows:
Episodes 1 & 2 - 17 April 2004 onwards
Episodes 3 & 4 - 19 June 2004 onwards
Episodes 5 & 6 - 21 August 2004 onwards
Episodes 7 & 8 - 16 October 2004 onwards
Episodes 9 & 10 - 18 December 2004 onwards
Episodes 11 & 12 - 19 February 2005 onwards
so still a long way to go yet.........
https://www.sau.com.au/forums/topic/39874-initial-d/#findComment-822557
b_real - the episodes you're talking about - are they new or repeats of the old?
Judged - I bought the whole series, all stages, across 4 dvds a while ago. Problem is I'm in England till Oct. If you can hang out till then I'm sure we can work out a DVD copy.. :P
https://www.sau.com.au/forums/topic/39874-initial-d/#findComment-825366
Judged - I bought the whole series, all stages, across 4 dvds a while ago. Problem is I'm in England till Oct. If you can hang out till then I'm sure we can work out a DVD copy.. :(
Thanks mate,
I hope you are having fun over there. Meet someone from a car club from england called CELTIC CRUISERS. Dont know much about em, but they seem to modifiy small compacks. I will keep looking around for initial D DVD's, but happy to take you up on your offer when you get back.
HAVE FUN :P
https://www.sau.com.au/forums/topic/39874-initial-d/#findComment-825636
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
