Hi all
I have decided to part out my year long effort White R34 GTT with full 4WD gtr runing gear. Reason being lost compression on cylinder 5, forced me to change my direction. Everything must go except the long motor as im rebuilding it for my future project.
GTR parts are off 2000 model V spec, and GTT parts are off 99 model
Here with the list:
R34 GTR parts:
Pearl white front bumper, with 1 month old GTR emblem and lower lip. some scratch on the lower lip but the front buper is perfect, also with turning light. $500
Year 2000 V-spec turbo, perfect with no shaft play $400
STD GTR injectors $200
Pearl White GTR aluminium bonnet, minnor dent on the front area, fine as is or suit respray: $600
Modified GTT bonnet catch to suit GTR bonnet: $80
Alumiunium Front guard left and right, paint stripped, minnor destorsion, will need to bog up and redone. $350
Gatrag 6 speed gearbox, perfect working order, good meat left on 4wd transfer case. comes with pull type AND push type fork and slave cylinder, 5month old nismo gearbox mount, and support brace, complete with GTR shift knob: $4000
Tail shaft: $250
Light weight flywheel (7kg) and exedy heavy duty single plate clutch: use less than 9 month with light foot, never launch, just bed in. paid $1600, asking, pull type $800
Vspec dash cluster, 25xxx or 26xxxkm on the clock (Rare very low K). $220
cream std GTR gear shift shround, complete with ash tray some minor scraches on ash tray. $150
G-sensor: $200
R32/33 Apexi Power FC, complete with hand controller. a minor scrach on the hand controller but wont affect the readding at all $750
Apexi boost controller. unit only no leads. $50
front subframe, complete with upright, aluminium lower and uppper arms, sway bar and front drive shafts, rare $1000
Std R34 gtr intank Fuel Pump. higher flow than pervious model, support up to 280kw awkw no worries, $180
Yellow jacket ignition module, 6months old, $300
GTR rear cradle, web strengthen, custom HICAS replacement with adjustable toe bar, with wheel hubs and drive shafts. $700
V-spec hydrolic diff, very little k's travel. strong bites $650
V-spec hydroic pump assembly, wiring hardness been modified, suit spare $200
STD rb26 AFM $150
GTR rear bumper in black, great condition. not a scratch $300
GTR twin turbo 60mm into 70mm front pipe. mines style, very good flow probably the best twin front pipe design. $350
34 gtr fujisubo Full exhaust. Jasma Approved. flows very well and very quite. made 300kw with this pipe before. $450
GTT parts (perl white):
Shell:with sunroof, it is been modified to take the GTR subframe and 4WD transfer case. It is still currently registered as RB25 auto, you can still put the stock rb25 gears in it and do the transfer, Happy to leave the trasfer date as blank so you can organise the RWC when all the work has been done. rego expires Nov this year so plenty of time to prep the car. Selling shell with glasses, boot, rear bumper, stock side skirt and dash and steering collum with Rego on $3000, without rego $2500.
head lights: $450
Stock pearl white front guard, $250
Doors with mirrors. $250 each
GTT wheel with Road worthy tyres : $350
GTT 310mm brakes, good pad meat left $500
GTT fuel pump $50
GTT front and seats, good condition, minimal stains $300
ask if you need any other parts
The car is still together in one piece, will try to get some photo latter today. only taking the stuff out when they are sold.
item located doncaster east Melbourne. Please PM for more info. I will reply all pm's ASAP.
Im not in extreme hurry or short in cash, so low baller will be ignored.
cheers
joe
Edited by godsmind
Hi joe, are these brakes front and rear, with calipers as well?
and how much for postage to 5160 s.a?
cheers, troy
Edited by rb20-into-mr30=
Year 2000 V-spec turbo, perfect with no shaft play $400, bare turbos, no suction bit and no downpipe.
Tail shaft: $250
G-sensor: $200
front subframe, complete with upright, aluminium lower and uppper arms, sway bar and front drive shafts, rare $900
STD rb26 AFM $150
head lights: $450
GTT 310mm brakes, good pad meat left $500 (on hold)
GTT fuel pump $50
GTR BOV $120/ pair or $70 each.
Intercooler hard pipes. HKS copies. $200
R32 intercooler $70
GTT wash bottle with motor $30
Battery: used for 8 month $50
Also have Tein Mono Flex coil overs. travel 20,000ks. $1000
GTR replica full carbon fiber rear wing with OEM height (custom requested for oem height) $400
center guages and shround $40
Boost pressure sensor $20
Viva garage GTR/GTT side skirts $200
OEM R34 sideskirt with front guard lower skirt, RHS minior twisted $250
Thick full alloy radiator 8 months old, suit R32 $100
Call or text 0433289998, genuine interest only
PS: pram not for sale ;)
Edited by godsmind
It was in the second part of the list....Here with the full list
Tail shaft: $250
G-sensor: $200
Yellow jacket ignition module, 6months old suit late model series 2 R33 GTR/GTst and R34 gtr, $300
GTR rear cradle, web strengthen, custom HICAS replacement with adjustable toe bar, with wheel hubs and, Cradle sold, Rear drive shafts. $200
STD rb26 AFM $150
Intercooler hard pipes. HKS copies. $200 Pending payment.
R32 intercooler $70
Also have Tein Mono Flex coil overs. travel 20,000ks suit R33/R34 GTR. $1000
OEM R34 GTR sideskirt with front guard lower skirt, RHS minior twisted $250
GTR replica full carbon fiber rear wing with OEM height (custom requested for oem height) $350
Shell:with sunroof, it is been modified to take the GTR subframe and 4WD transfer case. It is still currently registered as RB25 auto, you can still put the stock rb25 gears in it and do the transfer, Happy to leave the trasfer date as blank so you can organise the RWC when all the work has been done. rego expires Nov this year so plenty of time to prep the car. Selling shell with glasses, boot, rear bumper, stock side skirt and dash and steering collum with Rego on $2500, without rego $2000.
head lights: $450
GTT fuel pump $50
Viva garage GTR/GTT side skirts $200 SOLD
Edited by godsmind
Up, varies price adjustment
Tail shaft: $200
Vspec dash cluster, 25xxx or 26xxxkm on the clock (Rare very low K). $200
G-sensor: $200
Apexi boost controller. with leads. $50
STD rb26 AFM $150
GTR twin turbo 60mm into 70mm front pipe. mines style, very good flow probably the best twin front pipe design. $300
R32 intercooler $70
Also have Tein Mono Flex coil overs. travel 20,000ks suit R33/R34 GTR. $900
Shell:with sunroof, it is been modified to take the GTR subframe and 4WD transfer case. Selling shell with glasses, boot, rear bumper, stock side skirt and dash and steering collum without rego $2000, suit track car, Drop in GTR gear and ready to go.
GTT fuel pump $50
  • 3 weeks later...
