All parts are located in sydney castle hill 2154
can post at your expense, bulky items will need to be picked up
if any questions or need pictures ring or txt 0402362885
R33 GTR DASH - $120
R33GTR RADIATOR WITH SHROUD - $150
R33GTR BOVS WITH RETURN PIPE - $120 each of bovs or $280 for everything
R33 GTR GEARBOX - $500
R33 GTR CONDENSER UNIT - $100
R33 GTR INTERCOOLER WITH PIPING - $200
R33 GTR FUEL TANK - $100
R33 GTR REAR PARCEL TRAY - $50
R33 GTST BONNET - PERFECT COND - $200
R33 GTST 400R COPY SIDE SKIRTS - LITTLE BIT OF DAMAGE ON THE DRIVERS SIDE BUT EASY FIX - $60
R33 GTST RIGHT HAND SIDE GUARD - PERFECT COND - $120
R33 GTR STAINLESS STEEL CATBACK EXHAUST (NOT TOO LOUD BUT AWESOME TONE) (MAY FIT GTST) - $250
R33 GTR TURBOS with dump pipe and turbo manifoilds - $220
R33 GTR FRONT GRILL some cracks easy fix - $100
R33 GTR CARBON FIBRE SPEEDO WITH CARBON CENTER GAUGES - $250
R33 GTsT STANDARD EXHAUST - $120
R33 GTR SEATS with rear seats - DRIVERS SEAT HAS A SMALL TEAR PASSENGER SEAT STILL FINE - $400
R33 GTR REAR trims with seatbelt - $100
WORK EMOTION XD9 RIMS -- $2400 o.n.o
18X10 +18 OFFSET
GOODYEAR EAGLE F1 245/40/18 90% TRED (paid 320 each)
COMES WITH WORK BLUE LUGNUTS (paid 260)
ONE RIM HAS MINOR GUTTER RASH BUT OTHERS ARE STILL IN PERFECT NICK
CAN POST ANYWHERE AS STILL HAVE ORIGINAL BOXES THAT IT CAME WITH
RIM 1
RIM 2
RIM 3
RIM4
TIRES
Damage
MORE STUFF TO COME !!
  • 3 weeks later...
  • 3 weeks later...
R33 GTR DASH - $120
R33GTR BOVS WITH RETURN PIPE - $100 each of bovs or $250 for everything
WORK EMOTION XD9 RIMS -- $2200 o.n.o
18X10 +18 OFFSET
RIM 1
RIM 2
RIM 3
RIM4
TIRES
Damage
    • Holy hell! That is absolutely stunning! Great work!!!
