Hey all.
Just thought i'd update on my soundcard.... Auzentech Forte 7.1
It has been an awesome soundcard, despite the hatred for Creative labs drivers i've remarkably had no issues with them and the setup has perform flawlessly even after updates etc. The UI was also good with their software.
However my card... she died last night captain... :(
It basically makes a epically loud helicopter noise through the headphones (so loud it'll hurt ears). Mine was a Rev 1.2 card (with extra heatsinks etc) so it was the good board. The Rev 1.0 ones were known to fail quite quickly after doing some snooping around the net and forums.
The issue after doing some reading sounds like the interchangeable onboard OAMP failing. So i think it can be repaired as a mate of mine is good with a soldering iron and it's a simple 8 pin replacement job with an OAMP and a adaptor slot. So I'll post up either way how it goes as the OAMP i wanna use will be an upgrade over factory so should improve the card (for a $25 part, seems worth the effort).
Honestly for the money i reckon the sound card was some of the best PC money I've spent as combined with the Sennheiser 555 headphones, the sound was absolutely mint. Mine has lasted 4 years so not "too" bad however it really shouldn't have died realistically.
In the mean time i went and lashed out on a ASUS Xonar STX, will give it a whirl over the weekend and report back as if i fix the Auzentech card, it'll go into my media PC :)
Depends on the resistance of the headphones themselves.
The Senn 555s (595, 558, 598) and higher all benefit greatly from having an amp'd socket powering them and sound 100x better when plugged in.
Perhaps have a bit of a google and see if it'll offer any benefit. If they do then I'd certainly reccommend it as i do watch a few movies through headphones (given i cannot run my huge stereo @ 4am in an apartment lol), so it's a setup i get to use/appreciate pretty often.
What people should realise is that most music is optimised for listening on a stereo system and not headphones. A search for "binaural music" will yield samples that show how music should be sampled for headphones. Anyways, the HD-280 Pros also have 64 Ohms of resistance so an amplifier isn't needed.
but im guessing their test system was a home stereo not a PC
EDIT
a quick search shows for the HD555
Nominal impedance - 50 Ω
Ye probably not thinking PC Gamer/Music listening as opposed to proper amplified stereo. I've got a big mumma Marantz amp for that home stereo duties, the card simply processes the sound in that instance and does no driving.
But i can certainly tell you the difference was night & day when i put the soundcard in initially as opposed to using onboard.
When i was doing reading people did say you "dont need one", but there are "benefits to be gained" by having one. So ye, probably no point for yours by the sound of it
yeah that video review i posted has a few good things to say about the DX sound quality, SNR hearing footsteps behing you
also i get this weird anomaly watching WMC sometimes its a sound thing like maybe the onboard is overheating not sure
Oh missed the edit. at work anyway, cant watch it anyway
It could be electro interference or something dude? I noticed if i have my soundcard too close to the GPU it would sometimes "buzz", moved it another slot down and was fine.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
