Gday.
I have bought myself a track car and no longer have space for my gtr.
I am selling it absoloutely complete minus the engine (it is going in my track car)
It is a fine example of a 1989 GTR. It is gunmetal in colour and is in great condition.
Year: 1989
Colour: Gunmetal grey
Kms: 88000 (has a nismo dash but the car looks and feels like the kms are original)
Registered until november 2012.
As i said above, it is absolutely complete except for the engine. It will be a simple case of bolting in an engine and enjoying a great car.
Here are the parts that are on the car:
#R33 gtr brembo brakes all round (excellent condition pads)
#Nismo rear subframe (reinforced frame and stiffer bushes)
#Nismo shocks and springs (nice firm ride without the bone jarring from coilovers and also not stupidly low)
#Weds sport 17" alloy wheels (seriously light) few spots of gutter rash but overall nice condition
#Nismo gauge cluster
#Nismo gear knob
#Brand new top of the range Quiktrak alarm with gps monitoring/immobiliser etc
#Techtom device (great device that tells you water temp/actual speed/injector duty cycle etc
#Greddy Profec B spec II electronic boost controller
#HKS oil cooler and filter relocation kit
#Huge metalcraft intercooler
#Garage defend carbon radiator air guide
# brand new genuine nissan radiator
#brand new genuine nissan power steering rack boots (not cheap!)
#Tomei hicas lock unit
#Front lip
#N1 vents in front bumper
#May include bee r front pipes if price is right
If the price is right i can include a huge amount of rb26 spares including blocks, cranks, brand new forged pistons, prepped rods, turbos, engine covers etc. (almost any rb26 engine parts)
The body and paint are in good condition. There are are a few chips and scratches on the drivers side door and the right hand side skirt ideally would need replacing as it has blistered. Overall for a 1989 model it is quite good. Everyone always comments on how straight the car is.
The interior is in great shape as well. The drivers seat has only a tiny wear part and hasn't torn through. The rest of the seats are in great nick and there is only the tiniest little nick on the dashboard on passenger side. It is an original interior with a full set of mats in great nick.
The car will come with the personalised plates and the quiktrak alarm system with 12 months monitoring already paid for.
The engine is still in the car for the moment. There is probably lots of things i have forgotten to mention i will add them as i remember them.
With the long rego (november 2012) and the good condition of this car i am looking for $17500.
This car isnt some rust bucket that has been butchered and cut up, it is a great example of Godzilla.
If you think it is too expensive then this isnt the car for you.
Phone: 0422 729 679
Contact: Luke
PM me with any questions
Cheers
Luke
Edited by piranha
Forgot to add car has power fc with hand controller and momo steering wheel
$16500 or near offer.
If no interest may sell car running as is with built motor (pm for specs)
Cheers
No one interested in a clean gtr with lots of extras and long rego?
$16000 delivered within reason in sydney
Will come with a spare engine in pieces (detonated due to bad fuel)
$15500 or near offer (will deliver in Sydney within reason)
need it gone.
perfect street gtr, long rego, gps alarm and lots genuine japanse extras
Hey sorry I just need to make sure I read your add correctly....So you are selling a 1989 r32 gtr that doesn't have the motor (which means it doesn't run) of 15k?? The buy will have to source a motor, drop it in, run it on dyno to make sure it runs fine is that right?
If you're referring to the condition of the car it still has motor in it so it is running.
If you're talking about the condition of the engine that the buyer would drop in that's their responsibility.
  • 5 weeks later...
  • 3 weeks later...
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
