hey guys
tonight whilst driving my 32 i noticed that once it comes on boost it starts hesitating/ misfiring abit and a cloud of black smoke out the back. I put $20 of BP 98 in it before hand and thats when i started noticing it and thats the first time it happened, the night before i went on the Antilag cruise and again put fuel in before hand and it had no problems came on power fine and smooth.
the car has splitfire coil packs with standard BOSCH plugs, forward facing plenum with saard injectors and a 35R turbo with 44mm gate
im thinking it could be a bad batch of fuel?? possible coil pack?? and maybe the standard plugs have given up on life and thats causing the drama
it idles fine, drives fine with no misfire but as soon as it creeps up to about 4-4.5rpm as the power comes on thats when it starts to hesitate and misfire, sometimes its not bad then some other times its pretty bad any suggestions????
cheers
https://www.sau.com.au/forums/topic/398853-32-misfiring-hesitating/
ill try gets some plugs with that size gap, and thats what i though but drove till warning light was on went to a different servo and still the same result.
I put a set of platinum plugs in it this morning that i had sitting around, so i put them in and drove it the hesitation is gone but still has abit of a misfire i looked inside each coil pack when i changed plugs and cylinder 1 coil had a white powdery resedue and the little coil spring inside is like gone and all other coils are clean and have no pwdery stuff in it, and the top of the old plug was powdery and all crapped up, so i have a feeling its a combination of shit plugs which are failing when hot? and a crapped out cylinder one coil pack? i think the connection between the plug and coil is not good and spark has to jum further hence why still has abit of a miss??
ok so i swapped a whole coil pack assembly for all 6 cylinders and the harness from my mrs's car to mine and took it for a spin, still the same result, like a popping, misfiring sound, doesnt really seem to miss i think i can rule out its a coilpack if mine runs the same with 2 different harnesses, i even swapped the dud looking one with the white shit in it to her car and took hers for a drive and hers ran nicely no miss or hesitation, im going down the lines that the pooping/ miss sound is maybe from the screamer pipe under abit of heavy acceleration??, it doesnt do it all the time when on boost just sometimes through the rev range, might even pay to get plugs with a .8mm gap??
well the plug from cylinder 1, the terminal had like a white powdery substance all over it and same with the inside of the coil all the rest where fine but on some the insulator had like brown burnt marks on the bototm of it and around the centre electrode its all black with carbon build up, could this mean anything towards it having a misfire on boost??
took it for a drive with my original splitfires in and new platinum plugs and its the same on boost seems to have like a misfire/ backfire/ popping effect could this be tune related?? is it best i take it to a tuner to run on a dyno to see if they can spot any bugs??
could a air leak cause it to wanna miss on boost??
whats got me stumped is that i changed plugs and the hesitation had gone but still it seems to have a misfire/ popping/ backfire affect i changed the coil pack loom and coil packs over and no difference i even put mine on my gf's car and hers still ran nice and smooth with good power delivery.
so that kinda pulled me away from it being a coil pack issue, im even thinking it could just be it backfiring out of the screamer pipe, the car still goes hard, i was thinking even maybe a air leak in cooler piping or vac lines? its been raining here in perth and my AFM is in cooler piping so maybe water could of stuffed it up causing it to make the tune out of whack whilst i was driving it through puddles etc?
could be something as simple as i just need to get plugs with a .8mm gap?
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
