heya guys and gals.
spent the last 45 minutes fishing around for info on this... however every link that looks like it would lead me to the answers i need on here appears to be dead.
basicly. what front driveshafts/CVs are interchangable with my s1 c34 stagea? (r32/33/34 gtr?)
mine are absolutily shagged. clunk around corners, shudder at speed etc. between that and my shagged CAS the cars turned into a pig to drive.
if anyone can steer me in the right direction, much appreciated.
dan
I have not fitted one personally, but I am sure 32/33 and probably 34 driveshaft will be interchangeable.
The gearbox, block and diffs are all interchangeable, so the driveshaft must be too.
thats good to hear.
dont want to get a set of 33 gtr ones for example and find they have different splines for example...
ill keep digging around untill i find someone definitely confirming it however.
are S1 and S2 front CV's the same?
are they different for the S2 RS Four S?
id say they'd be the same throughout the whole range.. (pending that 32/33/34 ones all fit that is)
im still on the hunt for a pair from a gtr. ill report in to confirm they do fit.
  • 5 years later...
Update to an old thread.
I heard they are the same as a GTS-4.
Also heard more recently a Pathfinder uses the same shafts up front, possibly just the inner's,
I will clarify next time I chat to the mechanic.
Pete
Edited by Stagea_Neo
Spoke to the mechanic, only the left cv shaft is the same.
I just purchased a right cv shaft from Paul at Osaka Imports in Knox, Vic. (very helpful and friendly).
He has a left/passenger side shaft there if anyone needs one. (my left was ok).
Apparently it's the right side that usually go's.
  • 1 year later...
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
