SeriesIIGTST Posted May 1, 2004 Share Posted May 1, 2004 I just got one of these and don't have a guage to set base fuel pressure. Anyone know what pressure they come set with from the factory? Cheers! Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/ Share on other sites More sharing options...
rev210 Posted May 1, 2004 Share Posted May 1, 2004 get a guage. you need one and they are cheap ($20 odd) Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-817340 Share on other sites More sharing options...
BOOSTD Posted May 3, 2004 Share Posted May 3, 2004 they come set to standard pressure. I installed one a couple of months ago. Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-820337 Share on other sites More sharing options...
SeriesIIGTST Posted May 3, 2004 Author Share Posted May 3, 2004 nice one. Thanks boostd Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-820549 Share on other sites More sharing options...
rev210 Posted May 3, 2004 Share Posted May 3, 2004 Mate just go get a guage and make sure. I guess for the saving of $20 odd you can take the risk that you might lean out your nice new $5k rebuild. Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-820760 Share on other sites More sharing options...
SeriesIIGTST Posted May 3, 2004 Author Share Posted May 3, 2004 yeah, i was going to, just wanted to make sure that the drives to and from work that I will have to do before i get a chance to get to the shops wasn't going to be doing damage to my engine...like you say, i don't want another $5K rebuild! Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-820801 Share on other sites More sharing options...
Zombie Posted May 3, 2004 Share Posted May 3, 2004 I have one I havent installed yet, i'll let a pro do it. But out of interest, how are they actually adjusted? Is it tighten the screw to increase or decrease? Thanks Adam Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-821102 Share on other sites More sharing options...
BOOSTD Posted May 4, 2004 Share Posted May 4, 2004 increase Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-822665 Share on other sites More sharing options...
SlowGTS-t Posted May 7, 2004 Share Posted May 7, 2004 Is there more than one type of nismo adjustable fuel pressure reg? Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-829358 Share on other sites More sharing options...
Sydneykid Posted May 8, 2004 Share Posted May 8, 2004 Is there more than one type of nismo adjustable fuel pressure reg? Yes at least 2, one fits on the fuel rail and one is for remote mounting. Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-831398 Share on other sites More sharing options...
Bl4cK32 Posted May 8, 2004 Share Posted May 8, 2004 do you need one of these if you're running bigger injectors (550cc) and a 044? Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-831530 Share on other sites More sharing options...
Sydneykid Posted May 8, 2004 Share Posted May 8, 2004 do you need one of these if you're running bigger injectors (550cc) and a 044? Only if you need to increase the fuel a little more than the injectors flow at standard pressure. Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-831563 Share on other sites More sharing options...
SlowGTS-t Posted May 8, 2004 Share Posted May 8, 2004 sorry I mean are there different kinds for boost and vacuum apps (turbo & n/a) Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-831571 Share on other sites More sharing options...
32ZiLA Posted May 21, 2004 Share Posted May 21, 2004 Anyone know where you can get a fuel pressure gauge for $20? I've been looking around and I can get plenty that are 0-15psi, but I need one that goes to at least 60psi as the stock pressure should be 43 psi when the ignition is on for a GTR. Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-850894 Share on other sites More sharing options...
Steve Posted May 21, 2004 Share Posted May 21, 2004 do you need one of these if you're running bigger injectors (550cc) and a 044? Bai suggested Iget one to raise base fuel pressure to 3KG, as it will assist in making the car more responsive. Also, if you have Sard 550cc injectors, they are rated at 550cc at 3.05kg, at stock pressure 2.55kg, they are around 510cc. they also have a bit more lag than the stock injectors, I have +0.08ms correction for mine and they run sweet, but this is at 2.55kg - havent upped the pressure yet:) soon. Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-850970 Share on other sites More sharing options...
PSI_GTSII Posted May 21, 2004 Share Posted May 21, 2004 I have just fitted a rising rate reg to my RB30.... a fuel injector 'cleaner guy' was out today fixing a Leaky injector I had and was shocked at my fuel pressure...apparently 100kpa at idle...! He bypass'd the reg and got it down to 50Kpa, where it ran smoother... What pressure should it run at idle? Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-851510 Share on other sites More sharing options...
Steve Posted May 21, 2004 Share Posted May 21, 2004 100kpa is only 14.5lbs or 1 bar. What does the VL normally run? Link to comment https://www.sau.com.au/forums/topic/39889-nismo-adj-fuel-pressure-regulator/#findComment-851888 Share on other sites More sharing options...
