Make and Model: Subaru Impreza WRX MY06
Model Year: 2005
Registration: NSW
Pictures: Included
Colour: Silver
Transmission Type: Manual
Mileage: 133,4XX KMs
Rego: February 2013
Reason For Sale: I work in Sydney and commute by train 5 days a week so the car sees little light and will look at putting the money to better use.
History:
I bought this car from a bloke in his early 30's back in 2009 and it had approximately 99,XXXkms on it. He lived on the south coast and travelled to Appin (mine) for work which lead to high mileage - highway driving. The car had full logbook service history with Tynan Subaru Wollongong, was looked after meticulously and garaged for its whole life.
I have owned the car coming onto 4 years now in May and has been my pride and joy. The car has been maintained meticulously. It comes with complete logbooks from Tynan Subaru Wollongong and was quite frequently washed and maintained. It has been garaged its whole life. I regularly changed the fluids more frequently, particularly the oil, which was, changed every 5000-7500kms with Mobil Delvac. I have receipts/paperwork for all work carried out including receipts for modifications, service receipts and dyno sheet.
The last service was the major service and was completed on 06/11 with 124,XXXkms on it. This service included all belts etc.. required for the major service. The car has never been in any accident.
Since I bought the car I have performed a number of modifications keeping in mind practicality, performance, comfort and fuel economy.
Modifications include;
Engine;
- VF30 turbo
- PSR silicone intake with short fat bit
- TCP turbo back exhaust with STi style muffler
- Cosworth panel filter
- Walbro 255lph fuel pump
- 06 STi intercooler and y-pipe including splitter
- Optima yellow top D34 deep cycle battery
Suspension/Brakes;
- Eibach Springs
- Whiteline 22mm adjustable sway bar - rear
- Whiteline heavy duty allow links
- DBA 4000 slotted front rotors
- DBA Street Series slotted rear rotors
- ELIG Street brake pads front and rear
Wheels:
- Factory 17' Enkei wheels - one rim has a minor gutter rash approximately 6-7cm long, one rim has a minor scratch on the face approximately 2-3cm.
- Tyres are Bridgestone Potenza RE011 Adrenalins with approximately 60% tyre life.
Interior;
- Genuine WRX OEM floor mats
- Factory single DIN head unit
The interior has been maintained regularly with Meguiars products and is in excellent condition.
The car also comes with factory exhaust, springs and rear spat guards.
The car has been flash tuned by MSR on the 05/11/11 and produced 203awkw with max torque 630N.m at 86kph.
All modifications were fitted by either MSR or myself during 10/11 - 11/11 prior to being tuned except for the Eibach springs which were fitted 11/09 approximately 105,000kms.
Cons:
- minor door ding on passenger side door which is only noticeable if your looking for it
- I have disconnected the headlamp washer assembly (who needs it!) - the covers got stolen and the spring assembly doesn't work. I have since replaced the covers. Even before it got stolen the things never worked properly and would get stuck on return. I was planning on using the motor to do an Intercooler spray but just didn't get around to doing it.
- One or two minor stone chips - as you would expect and are unavoidable
I am a little negotiable on price but in no rush to sell. I still cant decide myself if i want to sell it or not..... I may consider swaps for a clean S15 + cash my way but prefer to sell.
Please no low ball offers or joy rides.
Cheers
nevits
https://www.sau.com.au/forums/topic/398907-nsw-eoi-my06-wrx/
  • 4 weeks later...
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
