Wanted Rb26 Longblock Or Engine
Engine $3500
HKS oversized forged pistons to make it a 2.7 litre. Extremely smooth/quiet running engine. Has only ever been run at under 280rwkw because of being safe side of injector limited with standard injectors/afm's. It has made 300rwkw with -5's on dyno but didn't want to run it with inj's maxed so turned the boost down a few psi and retarded the ignition. It will come wih all sensors, standard turbo's. Have never had a need to have the engine out of the car so unsure if its a R33 motor and what else has been done to it.
The car still has the old oil filter on it so check that for metal and i can sit the gearbox back up to do a comp check. Everyone knows me in the club and the car plus I'm a licenced aircraft engineer (helicopter) so lying doesn't really cut it in our industy/nature.
How do ou want it proven?
    • yeah, there's a country that recently started importing Skylines, I blame them.
