Evenly dispersed block stiffness - same level of stiffness in the center and the shoulder for stronger grip and traction, prevents irregular wear. Uni-Directional V-shaped main groove enhances streamline form and also improves aquaplaning ability at high speeds. Wide angle grooves increase block stiffness, further enhancing tire's grip and traction. Engraved pattern name along the groove creates an exquisite product image. Sub-grooves on the shoulder disperse block stiffness, improving ride comfort, grip and traction. Complete block stiffness provides excellent lateral stability in cornering. The 595RS-R is beefed up by reinforced steel on the sidewall to promote the sharpest high speed cornering and fastest lap improvement.
Proven on the circuit, the 595RS-R is highly acclaimed and much demanded for drifting, sprinting and track-day applications. The sleek design and ultra high performance of the 595RS-R makes it the number one choice for those requiring a motorsport tire but with the assured standards of a street legal tire. Even DOT approved or E-Mark approved Federal competition tyres are designed and compounded for competition use only and are not intended for highway or road use.
595RS-R
215/45/17 $190EACH
225/45/17 $200EACH
235/45/17 $205EACH
235/40/17 $220EACH
255/40/17 $280EACH
225/40/18 $240EACH
235/40/18 $240EACH
245/35/18 $240EACH
255/35/18 $260EACH
265/35/18 $270EACH
285/30/18 $280EACH
We also stock all Federal other range of tyres..call for a quote
https://www.sau.com.au/forums/topic/398987-federal-r-s-r/
  • 1 month later...
  • Replies 46
  • 3 weeks later...
Mods please delete my post above.
Hadouken
Appologies - meant to post on the guys WTB thread. Pointed him to here previously to buy new from OTR.
I was checking here to put a price on my Federals in case he was interested.
Posted in his thread but couldn't see it so posted again. (accidently on wrong page :wacko: )
Sorry Ken.
https://www.sau.com.au/forums/topic/398987-federal-r-s-r/#findComment-6455351
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
