Well I finally had my R33 GTR put on a dyno and slightly tuned. It is stock except for boost restrictor removed and slight timing adjustment.
I bought it when I was living in Perth about a year ago, which is where I had the initial tune done.
Before tune and boost restrictor removed it made 230hp at all four wheels.
After they removed the restrictor it made 288.2hp (214.99kw) at all fours.
Having moved to Canberra, different elevation and temp etc. I thought I would have it re-tuned.
Tonight it made 297.71hp (222kw) at all fours.
Feels slightly different in the way boost comes on but very happy. Not big numbers I know....But one day maybe! ; )
https://www.sau.com.au/forums/topic/399004-just-had-car-dynod/
Plans are:
  • Replace stock turbo's
  • turbo's back exhaust system
  • Cams and cam gears
  • Fcon Pro
Will do turbos and exhaust first and at the same time, then get the other stuff done. Unless I win that $50 million lotto draw! :rolleyes:
Not looking for extreme power. Something super responsive.
  • Not looking for extreme power. Something super responsive.
As someone who has done this (and still doing it), I'd suggest a couple of stages.
Stage 1
Part 1
Turbo's -9, -7 -5 (the smaller the better if you want response) GT'SS good but not worth twice the price of -7's
Exhaust including dumps and high flow cat
I think this should be able to be done without needing a tune, if it needs a tune save the money and get a computer (part 2)
Part 2
Computer, Haltech or Vipec most common and easy to work on with great support in Australia, unsure on the HKS Fcon pro, your choice.
Cam gears
Tune
Expect 260-280kw, fuel being your limiting factor.
Stage 2
Injectors, EG IDC1000
Fuel pump
Fuel regulator
Cams (if you want them)
Tune
Expect 320kw, depends on how hard you want to work the stock engine, this set up is good for much more power with more boost.
Stage 3
Full suspension approx $5000 in new parts + labour
Upgraded brake discs and pads DS2500 or Nismo's highly rated
Stage 4
big brake kit (optional if you find you need it) EG $5000 AP front kit
Stage 5
Rebuild
Stage 5 can happen any time :(
Most here can recomend ESP and Trojan (more good news then bad news anyway). Budget at least 20% more money then quoted for unknown problems that need to be fixed at the same time.
Yeah not likely to get any rust down here, unless its from salt during snow season! LOL
The CV boot cover and CV joint in my XT went during a drive from Sydney to Airlie Beach in Qld when we moved up there. The car started to shake at Mackay so nursed it all they way to Airlie Beach.
I actually think it happended on one of the caine rail crossings as we were fully loaded down and hitting them at about 120-130km's.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
