Hey guys.
So my car is not running at the moment, it's at my mate's Ultratune. It won't start/turn over. My mate believes the car has immobilised itself but it doesn't respond to my key. Any ideas on what could be the issue? We're thinking a new key with transponder might need to be made up?
Cheers
Hieu
so it will not physically turn over or it spins over but does not start?
one is a battery issue the other is transponder.
anything else done the car?
If it doesn't even turn over, it could be a transmission N/P switch if it is an auto, or a clutch switch if it is a 6MT. Assuming it isn't a battery of course..
Hey chris
It physically will not turn over. At first, we thought it was a battery issue but when we put in a new battery, still nothing. All the electrics work though, lights on the dashboard come on, headlights still work.
This is probably a dumb question.. but you are pressing the clutch when you try to start?
I'm not in brisbane, so I can't make any recommendations for auto electricians. Maybe Chris can.
Immobiliser wont turn on anything except for say radio. Hence when immob, the you can't hear the fuel pump priming as its been cut until immobiliser releases it.
I had the same problem this morning but that is because my key fob battery was dying. My FOB wirelessly disarms when the immob is armed eg; disarming and not starting the car which cause the immob to rearm. Rather than having to press the FOB, it wirelessy disarms while cranking over.
If the fuel pump and speedo etc isnt lighting up than immob/transponder issue.
Yes we depressed th clutch. On Saturday when it first started playing up. I had to open my car manually because the alarm and central locking didnt respond to my key fob. When I opened the door manually, the alarm went off but I couldnt switch it off, because it still wasnt responding to the key fob. I put the key into the ignition and tried to start it. None of the lights on the dash came on and it wouldn't turn over or anything. The only things working were the headlights and the headunit. I tried jump starting OT, still nothing so we don't believe its battery related.
Well its exactly what i said, you have not disabled your immoblizer so car will not start, its the first thing you should have tried, new battery for your key., did u tell ur mechanic the above? if so not a very good mechanic if he didnt immanently think the immoblizer and flat key ...
hey guys. it turns out it was just the batteries in the key fob dying. my mate replaced them and bingo! it was able to disable the immobiliser and the car starts fine :) thank you to everyone for their input!
    • Sell it and buy something newer? 馃槢
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
