I have x2 Z32 ecu suit R33 RB25.
x1 for series 1 Z32 ecu
x1 for series 2 Z32 ecu
I am able to program to NEW nistune board for your injector and AFM.
So you can drive to your tunes shop if you change injector or AFM your self.
Fuel and timing map is std so please do not rev.
Price $550 std R33 data and $600 tuned R33 data.
Price include Z32 ecu and NEW nistune board.
  • 1 month later...
hey, also interested. would you be interested in trading a standard r32 gtst ecu plus cash? was considering nistuning it and using it in my s1 r33, but it seems this'll be the better option.
If you come to me for tune I can R32 ecu trade in.
  • 1 month later...
G'Day Toshi,
Do you still have this ecu available? I've read that there are some internal mods that need to be done to the ecu to work on the R33 series 1 (I have 1994 model). I'm assuming you've already done these and fitted the Nistune board?
Unfortunately can't come and see you for a tune, as I'm in Perth (have read many good things about your work). But would be keen to buy off you if you can ship here.
Cheers,
Mark.
Yes , I have.
If you do not need tuned data I can do $550.
$600 is with street tune map.
Also I have race map.
This nissan laurel std turbo RB25 DET is real time tune race map.
If you are interesting same tune I can come Perth if I found over 3 people.
http://www.youtube.com/watch?v=Vb4kF8O531k
  • 3 weeks later...
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
