Hey people,
Some mates and I are arranging a cruise to the coast in a couple of weeks. Just putting it out there if anyone might be interested. Thinking a drive then bbq/pub lunch and head back. Deets can be found here Linky. Anyhoo everyone is welcome, were hoping for a good mix of cars for it. Still not sure 100% on the destination but most likely narooma.
Cheers
https://www.sau.com.au/forums/topic/399045-anyone-keen-for-a-cruise/
this is the original post
[ACT] Coast Cruise - Sat May 12
Was just discussing with Rorge and Eatabag, we're thinking of doing a coast run on Saturday the 12th May.
Head down, BBQ lunch or pub lunch somewhere, and cruise back ... laid back and relaxed, nothing to serious.
Meet Jim Murphy's Carpark, near the Servo, 8:30am for 9am departure?
Should be a good day and hopefully the weather will hold out for us. :)
42?
you mean 24?
14
hmmm out of those 3, I'll take 24! :D
And Richard I was so nice calling you a youngun the other day and then you go and post that :angry:
Me too!! My birthday is on the 13th though.
The Wakefield Matsuri is on that weekend, so a few people will be in Goulburn.
Yay! Another Taurus! Mine's the 9th
You'll need something to do during the day tho shell. So do we count you in?
I'm having it in Sydney, otherwise I'd love to come along Stephan.. gotta support team R34 :D
Awwww Shell you got me so wrong. I simply meant you are the meaning of life itself.
Answer to the Ultimate Question of Life, The Universe, and Everything from the supercomputer, Deepthought, specially built for this purpose. It takes Deep Thought 7½ million years to compute and check the answer, which turns out to be 42 ~ Hitchhikers Guid to the Universe
^awesome movie
I would consider going but i probably can't afford it at the moment
OK forgiven :wub:
This is not the first time someone's used a Hitchhikers Guide to the Galaxy reference and I've had NFI what they're on about :huh:
"Thats exactly the kind of thing we need to know; do people want fire that can be fitted nasally?"
hey guys, any older skylines or mostly new?? as mines kinda crapish...(not many mods) also is there any further details??
Doesn't really matter. if its a car and not a prius its pretty much ok. No more details yet. I'll stir the pot and get some more.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
