I'm going to go against the grain a bit and say a netbook, lol. Half the price of a decent tablet, and twice the power and versatility. I have an acer aspire 1. It runs a dual core 1.5ghz processor. Cost under $300 when I got mine. it runs dual boot android and windows but I never use Android because of the lack of an app market, but I have had a play around on it. Loads fast and is functional.
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6338870
My missus has the Asus Transformer which has the keyboard that clips onto it. Awesome bit of gear but a little on the expensive side.
Im using the transformer to write this.
Pros:
Decent battery life(especially with the keyboard)
Key board has usb port.
Pad has internal memory, and micro sd card.
Keyboard has full sd card slot.
Pad has micro hdmi out.
Plenty of games and apps from android market.
Can use mouse pad and touch with keyboard connected.
Live wallpapers.
due to extra battery in keyboard, you can charge keyboard whilst using the pad elsewhere.
Cons:
Web browser freezes every now and then, have to press wait.
Limited number of web tabs to open.
If trying to type with on screen keyboard, if you drag fingures a little, swype kicks in.
Speakers not super loud.
Youtube sometimes takes forever to load. Last update made it better, but i find, you have to close backgroud programmes.
I am biased, but the new iPad is sweet.
Considering a tablet is basically a screen, and the iPad has the best screen.. It's the best tablet, IMHO.
FLASH PLAYER!!!!!!!!!!
IPHAIL LOSES AGAIN :)
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6338907
Pros:
Live wallpapers.
Can root and run Android Revolution HD
Cons:
fixed check link to ROM on XDA
disclaimer: before rooting and installing ROMS on your tablet/phone RTFM
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6338921
Agree with this.
Less cost, more usability.
Or if you got cash to burn, you can pick up one of those 13.3" ultra portable laptops around $800-$1k (most will have i3 or i5 & some have SSDs so loading times will be a none issue)
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6339052
Most good sites use HTML5 these days anyway, Flash is a dying format.
Bullshit. f**k all sites use HTML 5. Sure, it's going to grow and grow and grow and eventually all sites will run it (or HTML 6, 7 or 8) but for now and the short to medium term Flash still runs 95% of the internet.
No Flash - iFail.
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6339894
+1 for netbook - the difference in usability can't be understated. A netbook is a complete PC whereas a tablet is basically a phone with a bigger screen.
I agree that netbooks are superior. If you do not need the out and out compactness of a tablet get s laptop/netbook.
However, if 90% of the time you'll be using it while sitting on a train or something, get a tablet.
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6339898
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
