I'm going to go against the grain a bit and say a netbook, lol. Half the price of a decent tablet, and twice the power and versatility. I have an acer aspire 1. It runs a dual core 1.5ghz processor. Cost under $300 when I got mine. it runs dual boot android and windows but I never use Android because of the lack of an app market, but I have had a play around on it. Loads fast and is functional.
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6338870
My missus has the Asus Transformer which has the keyboard that clips onto it. Awesome bit of gear but a little on the expensive side.
Im using the transformer to write this.
Pros:
Decent battery life(especially with the keyboard)
Key board has usb port.
Pad has internal memory, and micro sd card.
Keyboard has full sd card slot.
Pad has micro hdmi out.
Plenty of games and apps from android market.
Can use mouse pad and touch with keyboard connected.
Live wallpapers.
due to extra battery in keyboard, you can charge keyboard whilst using the pad elsewhere.
Cons:
Web browser freezes every now and then, have to press wait.
Limited number of web tabs to open.
If trying to type with on screen keyboard, if you drag fingures a little, swype kicks in.
Speakers not super loud.
Youtube sometimes takes forever to load. Last update made it better, but i find, you have to close backgroud programmes.
I am biased, but the new iPad is sweet.
Considering a tablet is basically a screen, and the iPad has the best screen.. It's the best tablet, IMHO.
FLASH PLAYER!!!!!!!!!!
IPHAIL LOSES AGAIN :)
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6338907
Pros:
Live wallpapers.
Can root and run Android Revolution HD
Cons:
fixed check link to ROM on XDA
disclaimer: before rooting and installing ROMS on your tablet/phone RTFM
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6338921
Agree with this.
Less cost, more usability.
Or if you got cash to burn, you can pick up one of those 13.3" ultra portable laptops around $800-$1k (most will have i3 or i5 & some have SSDs so loading times will be a none issue)
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6339052
Most good sites use HTML5 these days anyway, Flash is a dying format.
Bullshit. f**k all sites use HTML 5. Sure, it's going to grow and grow and grow and eventually all sites will run it (or HTML 6, 7 or 8) but for now and the short to medium term Flash still runs 95% of the internet.
No Flash - iFail.
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6339894
+1 for netbook - the difference in usability can't be understated. A netbook is a complete PC whereas a tablet is basically a phone with a bigger screen.
I agree that netbooks are superior. If you do not need the out and out compactness of a tablet get s laptop/netbook.
However, if 90% of the time you'll be using it while sitting on a train or something, get a tablet.
https://www.sau.com.au/forums/topic/399053-tablet-choice/#findComment-6339898
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
