Sup guys!
I am seeking some wisdom and advice from you guys, figured this would be the best forum to ask. Names Dave, im from SA. I turn 21 this month.
For a long time I've wanted an R32, in my opinion its the best looking skyline, along side 34s. Ive looked at importing a 32 from japan because they are very old cars and I would want one with low milage. Id assume there would be a shitload of thrashed out ones in Australia. I figured I could get one for around 8k. But then I looked at GTRs and noticed they were around the 15k mark, I had a rethink. I decided I would rather get a GTR.
However, I do know they are very old cars and do possess a few problems like the oil pump. Im guessing there are more problems which would arrise.
I need some opinions.
1) Would I be better off to import one, or buy from Australia which I can actually see. Keeping in mind I was keen for a stock gtr to avoid the risk of defects and regency checks.
2) If I were to import would importing a 1994 model be the smartest idea? If buying from Aus, would it be best to buy one with a rebuilt motor?
3) What problems do these cars typically have with age?
4) Best company for insurance?
If anyone can think of other reasons I should/should not buy one, please feel free to say so!
Thanks for your time kids!
Edited by Vanilla Slice
https://www.sau.com.au/forums/topic/399098-noobie-with-32-gtr-questions/
Buy it locally.
Get it looked over very thoroughly.
Be prepared to spend money on it. And proper money too. Easily thousands. A $15k R32 Gtr will be ruff round the edges.
As for insurance, your 20. expect to pay HEAPS for full comp insurance. thats IF anyone will insure you.
EDIT- Im not trying to sound negative, but old imports are expensive toys!!!
Edited by adamskill
Look locally first and if you don't find any that suits what you want then start looking at importing. 15k for a GTR, expect to put in at the very least another $5000 to get the car fixed up. No real advantage to a later model mainly just not being as old as a 1989 model. As for problems, just generally wear and tear on a 18+ year old performance car, also coil packs, AFM's and o2 sensors seem to be pretty common problems. Rebuilt would be the way to go if the work has been done by a workshop that know their way around skylines, and make sure they have all receipts for the work done. I have been insured by both JustCars and Shannon's and both have been around $2000 a year with a $1500 excess (JustCars )and $900 (Shannons).
My car was on the boat to Australia while I was still on my p plates and got the car not long after I had turned 20. I haven't had any problems in nearly 1.5 years of owning the car.
First of all search for answers, a lot of your questions you will find have been answered, 93 onwards have less issues with the oil pump due to the front of the crank being a better design. As stated above, AFM's, Coils, Exhaust cam.. Then there is the big stuff that cars of this age might need.. Clutch with labor (may as well rebuild the box too)- thousands, Turbos-thousands, spin a big end- THOUSANDS...
I bought mine because all I wanted was to own an R32 V-SpecII, I will never sell it, and I have had to make sacrifices to do it. All I have had to do so far is turbos (on the big $$ list) the things to think about are:
How often will you drive (often- get a 33 Gtst, very rarely- Maybe get a 32 R)
How much mechanical knowledge do you have?
How long do you want to keep it?
Are you happy to have car that consumes money, but very rarely sees the light of day..
Having said all that, I am taking mine to Wakefield this weekend, and cannot wait, everytime I drive it I get a buzz, I love looking out my kitchen window and seeing it.
Insurance wise mine is with Shannons, limited use, agreed value of $25k,the mods listed I am 29 with an all but perfect driving record, and is $1500ish.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
