FS Purple DR30 RS
1983 DR30 Skyline RS Turbo ‘Ironmask’
2.0l FJ20ET
5 Speed manual
New Daiken clutch
Midnight Purple
Jenesis Front spoiler extension
15 x 6.5 SSR Formula Mesh Alloys
Cusco Adjustable Camber Tops
Cusco Adjustable Front Strut Brace
Lowered suspension
Hi-flowed FJ20 Turbo (T3)
3” Kakimoto Exhaust (Dump pipe back)
Front mounted intercooler
GREX Oil Cooler with remote oil filter
VL Turbo Fuel Pump
GReddy ‘PRofec A’ Electronic Boost Controller
GReddy Turbo Timer
GReddy Adjustable Pressure Relief Valve
PROF Sheepdog Adjustable Blow-off valve
Pod Filter
Mines Ecu
Kenwood CD/Tuner/Tape
Bride Fixed Race Seat
Half Cage
Pivot Shift Light
Ultra Speed meter
Trial ash tray (best mod)
GReddy 60mm Electronic Boost Gauge (2.0bar)
OMORi 45mm Oil Pressure Gauge
OMORi 45mm Water Temperature Gauge
OMORi 45mm Oil Temperature Gauge
OMORi 60mm Exhaust gauge
Spares:
-R200 LSD
-FJ20 Turbo/Exhaust manifold/dump pipe
-Inlet manifold/throttle body/fuel rail
-Standard FJ20 ECU
Just had low km FJ20 fitted, with compression report.
Will require ADR compliance and rego
$8500
[email protected]
  • 1 month later...
 Share
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
    • Yeh a meagre benefit, what strut tower brace are you using? Eventually all the suspension and tyres are done and you get to ... meagre benefits. Narrow end of the wedge, all that stuff.
    • Yeh not doing anything with spacers at all, ty for the info
