hi guys looks like im up for a new clutch. when going down the qtr .. i cant smash 4th, it locks me out but will go in if i gently put it in. besides that all gears select fine. but a little notchy in normal driving
i dont know the brand of the clutch but it makes a chi-ching noise on start up (sounds boss)
so before i come to big dollars of new synchros il do the clutch
racepace have advised to get the nismo twin plate. has a hefty price tag..
what clutch have you guys used? what price? how many kms do you get out of it? is it good for qtr mile launches? (i dont track)
i just want a long lasting clutch because the one i got is appently only 10000km old
cheers
https://www.sau.com.au/forums/topic/399153-what-clutch-to-get-in-34-gtr/
  • Replies 44
yeh i know its the best clutch hence why the recommended it. i made my own thread because of my situation
what kms people getting out of the clutch? where can i buy it from and whats the difference between the c spec?
Aaaahhhh, this old chest nut. Seems to be the new hit topic.
Coppermix fanbois, how are we? Haha
Mate if you got dosh, buy the coppermix, if you're stinge then get a npc 10"single button.
Easy peasy.
As for mileage, mr pig did a lot of abuse and the clutch still looks mint. So if you're worried about durability, don't be. Just don't ride the clutch.
Have you been riding the clutch you have currently?
Just did 35,000 of hard kms with close to 400 RWKW most of its life. Easily 250 7000 RPM launches on it. Engine came out 2 months ago and it's going straight back in. No rebuild, no new plates.
C spec is rated at 780 ps where as the normal version is 640 ps
KM will obviously depend on what sort of life you put it through.
Regarding sourcing one, I suggest you speak with Andrew from Kudos Motorsports - nice guy and knows his stuff. www.kudosmotorsports.com
Nismo kit comes with light weight flywheel - etc already too.
Hope this helps.
Edited by iwanta34gtr
yeh i got the oil changed and apperntly the wrong oil was put in before hand. dumb c**ts
so now theres the catrol pil in it. it has helped a bit but will need a clutch
i wont go stingy il get the best out there but i want my moneys worth. if i buy it myself i can save some money . anyone know some good suppliers to compare prices?
as for riding the clutch. all i do is find friction point then a split second im off the clutch. just to save the jolt.. is this wrong?
the gears felt the same before i baught it to now . it was only the 400m that i noticed 4th had issues
Best supplier for those is; elrodeo666 on these forums. He is in Japan now, so send him a PM and he may take a few days to reply but don't stress, he's a very honest and helpful person and the prices are great.
+1 sourced my coppermix twin thru him, great guy to deal with and was very fast delivery from jap
Does he manage to get parts past customs and GST? I'm not a fan of unnecessarily paying tax and duty.
Never paid anything and thats including a Nismo intercooler.
Even the head is coming in 'carry on luggage' haha!
it's amasing what can be stuffed in a bag and shoved in the over head,
I have Excedy twin in the 32, and Excedy triple in the 34, not had a drama with either, the twin is silent and drive better then the factory clutch and has about 1000 7500rpm launchs and this kind of abuse
the triple is a bit niosey and a bit bitey, but takes the same abuse without fail
That is very impressive !!
will have serious look at them next time round !
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
