Yes, but that's the NON competition version... Hence the 640 ps power rating.
Hi Paul.(anyone) I was wondering if you have ever driven with an OS Giken Quad, if so, what fells different to you C Spec??
As you know I have bought the Twin C Spec and it will go in with the build.
The quad is driving OK since I got some torque down lower but the peddle seems stronger than I remember a clutch felt, only had Autos for 8 years since the TT300ZX.
It would be nice if it was a bit softer under foot, especially after an hour or so in peak traffic, getting old :blush:
  • Replies 44
I will buy your Cspec if you wish to keep your quad ! :D:P
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
