  • Replies 43
hey guys, the problem went away for a few drives now its back, not as bad as before but its still there. cleaned the afm with contact cleaner so pretty sure thats fine. My question now is (assuming it is the ecu), if i take my car to get a tune up (nisstune ecu) will this hopfully rectify the problem. Do tuners usually have spare temp sensors etc on hand if it is damaged, or should i be looking at coming with an arsonal of spares.
In my opinion it's a bad idea to rock up to a tuner with a car that has problems, a tune won't magically fix it.
exactly my thought
guess ill start troublshooting, starting with the temp sensor, makes it hard when its perfect one day and playing up the next.
Ok finally got some spare time to have a look at the NIStune files for warm up timing, i found that 7+ degree's of timing is taken out during warmup up till around 3000rpm then returns to normal, So from now on everycar i do will have this timing put back in.
Kasko when we meet up in June at Eastern Creek i will fix it up for you :)
Sounds great thanks mate!
Thats exactly where it frees up and starts cruising.
Amazing how different it feels with 7 degrees timing
I think it was pulling far far more than 7 degrees, the map I saw had a dip from 20 down to 5 and when I looked in ecu talk it was pulling the maximum timing possible.
It doesn't do it this bad stock though, so I suspect when you start changing injectors/afms etc something else might kick in as well, unsure what.
Hey guys sorry about this, just making sure im following correctly. So its due to my ecu taking timing out when in warm up mode below 3000rpm. But because my car does this sometimes even when hot then this would suggest a temp sensor is possibly damaged telling the ecu the cars cold when really its warmed up, at random times at that?
No wonder mine started doing it as soon as i put the smaller turbo on. You bad boy you.
I am of the opinion there are two maps, cold start and sort of cold start as mine still pulls timing when I drive the car about 5-6 hours ago, eg in the morning it is fine (stone cold) if I leave work early it does it though the warm start map doesn't pull anywhere near as much timing and doesn't really bother me.
The other option is yes your temp sender is stuffed, is your fuel economy ruined? Plug in a consult cable and check the fault codes (not 100% reliable), or simply just check the output when cold and when hot with a multimeter, it should vary.
Edited by Rolls
table is what I meant not map.
There is a cold start and warm start timing map, these are the two that do the retarding. The warm start one is much less aggressive, I'd just duplicate it in the cold start map and then take a few degrees out of the warm start one.
Lots of other handy tables though, coolant temp ignition and fuel tables for when the car gets hot, I put big numbers 110c degrees cell and a bit in the 100 so if it overheats in summer I don't blow it up.
Edited by Rolls
took the car for a drive tonight. noticed the temp guage went up to where it normal goes (did take about 10mins to get there - way longer then it should be) and down then stayed only about 1/3 way up and wouldnt get up to the normal place where it sits. also when it was down the car was boggy and when it was up (briefly) the car ran alot better. obviously after 20mins driving my car had warmed up. my question is does the temp sender also tell the thermostat to open up. or is it my thermostat is not working correctly therefor the sensor telling the ecu if the cars at operation temp yet is getting tricked.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
