King Springs to suit 350z / V35
1" drop on 350z
~ 2" drop on V35
Condition: Good condition, had them on for about 12,000 kms
Price: $200 , cost $400 new.
350z Stock shocks from a 2005 35th Anniversary model with 55,000 kms
From what I have read these are a great upgrade for V35/G35, they will improve firmness/handling and handle lowering springs without blowing .. if you put 2" drop springs on stock V35 shocks I don't imagine they'll last long. 2005 onwards shocks were upgraded from the 2003/2004 models.
$400 ono for both springs and shocks and will fit the springs on the shocks for you for easy install.
Edited by hobbsy
Price drop $250 FIRM for shocks+king springs!
Also have 4x 12mm hubcentric slip on spacers to suit Nissan, $50 for all 4 or $25 if purchased with the shocks and springs ($275 all up)
Edited by hobbsy
  • 7 months later...
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
